Old 25th January 2006, 07:23 AM   #1
bkfix is offline bkfix  Canada
Send a message via ICQ to bkfix Send a message via MSN to bkfix
Default power amp output -help-
I think i'm getting rail volage at the output of my amp.
i only tap the switch on for a second and its putting lots of voltage out the speaker terminals i think dc?
i soldered new offset and bias pots in. becase one of them blew. during this split second test one pot warms up like its gonna blow again.
does this mean my mosfets are toast shorting it out?
bk components pro-600, class ab
i have schematics. can post pics of the case.
any advice on just using the case and PS and designing new driver boards for it.
Old 25th January 2006, 09:02 AM   #2
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Default Re: power amp output -help-
Then what are you waiting for.......
K a n w a r
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 25th January 2006, 09:57 AM   #3
sounds like excessive voltage feeding that failed pot.
Shorting component in that region of the PCB? or a short across a pair of PCB tracks?
regards Andrew T.
Old 25th January 2006, 02:06 PM   #4
lineup is offline lineup  Sweden
lineup's Avatar
I soldered new offset and bias pots in
If something is wrong with a bias potentiometer
it can destroy a lot in an amplifier
Be sure to always control that bias pot is okay and attached correctly.
A little fault here and it can make real fatal error
lineup
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
Quad II power amps......power output transformers!!! bwes87 Tubes / Valves 3 10th September 2008 02:20 AM
Output power VS Peak output power Nordic Chip Amps 5 25th September 2005 05:08 AM
power output higher than power supply...How? loonatron Analogue Source 9 24th March 2005 07:04 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
Page generated in 0.09971 seconds (66.55% PHP - 33.45% MySQL) with 10 queries
