Could a TO225/Case 77 type transistor such as the BD135-139 types be used as input trannies in a general 50-80V design, or must the wattage remain in the 1W range of TO92 packages?
Is it not better to burn out, than to fade away? |
#2 |
Input transistors are usually chosen for their electrical performance, not the packaging. If a transistor performs suitably for your design, use it.
You will quite possibly catch some flak for using those particular devices though.
Jesus loves you. |
#3 |
No reason why you couldn't and the amp will work. In almost all cases though the lower noise - higher gain transistors are only available in the smaller packages.
Cheers
http://sites.google.com/site/quasisdiyaudiosite/ |
| What transistors do you recommend for a good LTP input? | EWorkshop1708 | Solid State | 14 | 3rd September 2011 12:37 PM |
| BC54x versus 2SC54x as input transistors | ash_dac | Solid State | 2 | 29th May 2006 02:35 PM |
| Input Differential Pairs and Zetex Transistors | EchoWars | Solid State | 6 | 19th June 2003 01:41 PM |
| Input transistors burned/replacements | 2Bak | Solid State | 40 | 31st August 2002 04:45 PM |
| Page generated in 0.06889 seconds (69.16% PHP - 30.84% MySQL) with 10 queries |
