Can someone explain to me why there is a thermal compensation bias in the attached schematic of a MOSFET amp? Couldn't this just be replaced with a single resistor?
Is it not better to burn out, than to fade away? |
#2 | |
Even if lateral MOSFETs were used, it would still require thermal compensation, because the driver BJTs would require it. |
#3 |
Vfets have a positive temp coefficient upto a very high Id. Check the datasheet to see at what current it becomes negative temp. coef. They will destroy themselves if you don't look after them. This schematic looks like it has been designed properly. You posted a schematic without a credit for the designer or simpler to post a link instead.
regards Andrew T. |
#4 | |
I know it's not popular to quote oneself, but I really have to reiterate this:
#5 |
![]() better to have to-126 bias generator, in the schematic is to-92 |
| Biasing/thermal compensation of Thermal Trak transistors | Bob Cordell | Solid State | 156 | 11th December 2010 09:38 PM |
| Thermal compensation | lumanauw | Pass Labs | 1 | 23rd April 2005 08:32 PM |
| thermal compensation | djdamix | Solid State | 19 | 1st April 2005 08:58 AM |
| Thermal compensation | DarkOne | Pass Labs | 5 | 30th December 2004 09:55 AM |
| Page generated in 0.10745 seconds (69.79% PHP - 30.21% MySQL) with 11 queries |
