Old 23rd January 2006, 02:42 PM   #1
Default can someone help me on my first mosfet amp?
hello everybody, i am new here. first time dealing with mosfets. i recently built this circuit which can be found below. i tested only one channel of it and had problems. i tested it first without the mosfet load and the 7805 did manage to give me a 5V reading. but however, once i reconnected the mosfet load back, the 7805 ouput voltage jumps to around 11V. the rails voltage is around 16V. i tried hooking up a signal and a speaker but there was no sound. anyone got any idea what could be wrong? thanks in advance
Old 23rd January 2006, 03:07 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
I recognize this circuit from
DIY Hi-Fi class A MOSFET amplifier
I do not know what can be problem.
Test that your 78L05 isnt broken.
Check that you have connected everything correct.
You have +16V and -16V ?
datasheet of IRF530
http://www.bmm-electronics.nl/docume...ild/IRF530.pdf
lineup
Old 23rd January 2006, 04:12 PM   #3
ilimzn is offline ilimzn  Croatia
This circuit will only work well if diodes D1, 2 and 3 are thermally coupled with the heatsink of M2. M2 and ancillaries are a current sink, and a rather convoluted one at that, look at some of N. Pass' designs for a simpler one. It is probably that the 78L05 is undercompensated, and it oscillates, since there is very little load. Put a 10uF electrolytic in parallel with C2, that should cure it.
BiCMOS Bipolar+MOSFET better than MOSFET lineup Solid State 5 8th December 2009 11:46 AM
New mosfet amp from ESP B.VDBOS Solid State 139 2nd July 2004 03:18 AM
MOSFET/MOSFET amplifier jarek Pass Labs 21 22nd June 2004 05:04 PM
The best Mosfet for the ZOZ ? ralf Pass Labs 6 9th January 2002 05:41 PM
Page generated in 0.07428 seconds (71.64% PHP - 28.36% MySQL) with 11 queries
