The unbeatable sound system, vastly superior quality of reproduction...guaranteed!!!
Old 24th January 2006, 09:14 PM   #61
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
PA is the same as Hi-Fi but louder (should be thought this way)
Old 24th January 2006, 10:33 PM   #62
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by awpagan
carlos
interesting post
honestly hadn't though about using the amps that way
"cutting input frequencies"
amplifying only the frequency range you want.
will try it.
but need the other amp finished first.
only need 2 amps ( 2 way speakers)
Question
How will the preamp handle driving 2 to 3 amps?
Could affect Zout, Zin
didn't like the idea of opamps btween preamp and amp.
alan
Building 4-7 Chip Amps (or gainclones) using LM3875/LM3886/LM4780
is a quick way to make an active amp-speaker system.
Can be two way speakers = 4 amplifiers
Can be two way speakers + sub = 5 amps
Can be three way speakers = 6 amps
Can be three way speakers + sub = 7 amps
Question
If you use preamp -> active crossovers -> power-amps -> tweeter/woofer
Active crossovers will have 4-7 outputs to drive 4-7 power-amps.
Each power amplifier is directkly driving each separate speaker element voice coil
(without any caps and inductors filters)
preamp -> 1 buffer input OP-amp feeds all active crossovers
You say you do not want OP-amp between preamp and power amp.
I say, I prefer this, to have passive filter caps and inductors between power amp output and speaker drivers.
And power amplifier adjusted to drive in a limited frequency span
with a specific single voice coil as load.
OP-Amp based filtering using low value film caps and resistors is simply superior to
big value capacitors and inductors in a passive speaker crossover.
lineup
Old 24th January 2006, 10:50 PM   #63
carlosfm is offline carlosfm  Portugal
Banned
Originally posted by lineup
Question
Considering that I use an AD815 current feedback opamp on my pre, and that it was made for video, to drive 50~75 ohm loads, high output current, that's no problem.
Old 25th January 2006, 01:12 AM   #64
mastertech is offline mastertech  Australia
Banned
Gratako-
It's like having an all star team that never practiced together.
sounds like Carlos and his buddies
seriously there is potential there in theory to create something
unique but then again i see even more in the conventional stereo
field, so i am happy for you guys hope you dont mess up with all
that circuitry and wiring, good luck in PA
Old 25th January 2006, 02:00 AM   #65
Banned
Eva-
anyway, why dont we call it all audio eva-end if you see no difference
Old 25th January 2006, 03:03 AM   #66
lineup's Avatar
Originally posted by mastertech
Eva-
As I got it:
A high power HIFI can be used as PA.
PA should not be used for true HIFI.
PA main purpose is good public announcement.
To acheive this you are willing and sometimes have to sacrifice some sound quality.
This goes for PA loudspeakers as well as amplifiers.
lineup
Old 25th January 2006, 03:13 AM   #67
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
If someone could design a L/R 12 db from two individually adjustable 6 db filters - that might work
But I think there would still need to be some passive RC to regulate impedance
Old 25th January 2006, 04:19 AM   #68
Eva's Avatar
lineup:
Have you ever had the opportunity to play around freely with PA gear in big open fields? (yes I've had, probably more than a hundred times)
Actually, I think that most people here would start hating "hi-fi" (as they know it) and would become addicted to things like horn bass if they were left playing with the right gear for a long enough time
What you can hear in live performances is not the whole story, as you will be almost always listening to a mix made out of 20 or 30 microphones placed in a noisy stage (having several monitors!!), with a lot of reverb applied as a desperate attempt to make up the mess a bit. Also, what you hear in night-clubs and big discos is not a good PA reference, because you will be usually listening to a mix of low-quality recordings made by some DJ that has no equalisation abilities and is not even allowed to listen to the "PA side" because he or she is trapped inside a cabin and only has a pair of small monitors or headpones as a reference. (I use ear-caps when I go to these places, this way I get more or less the same sound reference as the DJ does ).
Of course, the so called "high power hi-fi" produces quite frustrating results when you attempt to use it for PA, since it's almost unavoidably made out of low-eficiency direct radiation drivers, and as you go 15 or 20 meters away from the speakers, it starts sounding like one of those low-cost AM radios powered with two 1.5V cells (trebble and bass disappear, and also midrange does when the system is not aligned to radiate on-axis, because there are no room walls or ceiling to reflect it back to you).
Old 25th January 2006, 05:16 AM   #69
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Wonderfull...people are starting a "brain storm"...this will be productive to us, to
Have the opportunity to learn.
I am very happy with you here Eva, as you are a very good professional.
Very competent.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 25th January 2006, 06:02 AM   #70
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Perhaps. But for some weird reason I just feel that pro audio is less intimate than "hi-fi". Plus, no one ever needs to reach the high SPLs in their home that pro audio equipment is capable of. Proper gear and a good setup can most certainly sound great though.
Of course, the so called "high power hi-fi" produces quite frustrating results when you attempt to use it for PA...
Conversely, the PA gear can produce quite frustrating results when you try to use it in your home. They're each meant for specific applications so you guys really aren't comparing similar things. Plus, the wife acceptance factor for PA equipment is far too low
Brian
The unbeatable sound system, vastly superior quality of reproduction...guaranteed!!!Hide this!Advertise here!
Nature's sound reproduction... Vikash Everything Else 0 10th August 2008 01:13 AM
New boy looking for proper sound reproduction NJE807 Introductions 3 7th April 2008 04:19 PM
Sound stage reproduction methods Tyimo Multi-Way 1 12th February 2005 07:29 AM
sound reproduction and distortion tech.knockout Multi-Way 13 16th March 2004 05:40 PM
