S - Paul P32 amplifier
Old 21st January 2006, 03:26 AM   #1
MGR is offline MGR
Default S - Paul P32 amplifier
Hi to everyone
Has anyone by chance repaired an amplifier by the name S-Paul P32?I got this amplifier with both channels damaged,some of the resistors and parts are beyond recognition.It would be a great help if anyone has schematics for this unit.Attached are pictures of the unit.
Regards MGR
Old 18th August 2006, 01:10 PM   #2
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Hi MGR,
any luck with the amp yet?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 19th August 2006, 02:35 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Looks like we need to reverse engineer it or get a schematic.
Old 16th September 2006, 08:00 AM   #4
audiomachines is offline audiomachines  Philippines
Send a message via Yahoo to audiomachines
hello,
I hope this could help. This is a P22 Spaul Amplifier. This came to my shop today for service. Maybe you could get some clues. Observing your pics, the burned components are a rectifier diode and two resistors.
Old 16th September 2006, 08:02 AM   #5
another pic
Old 16th September 2006, 08:04 AM   #6
top view of the board
Old 16th September 2006, 08:27 AM   #7
another top view
here are the arrangement of the components 1/2W 100 ohm resistor,
1/4W 4.7K ohms, 1N4007 with the cathode pointing at the rear of the amp then the busted 47uF/160V elec.cap Hope this helps
Best Regards,
Audiomachines
Old 16th September 2006, 03:51 PM   #8
Leolabs's Avatar
Looks like you got a damaged driver stage.Wondering is the output stage damage too???
Old 16th September 2006, 11:54 PM   #9
no damage on the driver stage or the ouput, the turn on delay/dc protection ckt. is the problem, It takes 45 seconds for the relay to activate, While the "normal" is around 5 to 10 seconds.
Old 18th September 2006, 06:11 AM   #10
MGR is offline MGR
Thanks audiomachines but I have sincescrapped the original circuit , I have reverse engineered it and I found out the topology used was Class AB with the output in series connection to handle the +- 100V supply.I have replaced it with a Class H design.
S - Paul P32 amplifierHide this!Advertise here!
Paul Harvey is gone... moray james Everything Else 1 2nd March 2009 02:10 AM
Paul Hales has left QSC! Zero Cool Multi-Way 3 18th October 2008 02:12 PM
Question for CarlosFM & jean-paul georgehifi Solid State 3 28th August 2006 11:43 AM
Paul McCartney's latest CD John Hope Music 2 31st October 2005 07:36 AM
