has anyone heard of this? composite collector load.....
Old 20th January 2006, 02:02 AM   #1
coffin is offline coffin  Taiwan
coffin's Avatar
Default has anyone heard of this? composite collector load.....
Hi
Recently I found an old article of a power amplifier.
It uses the technic of "composite collector load class A", means the output transistor will always stays at Class A using such a technics......
It seems had been post on the "Practical Electronics" magazine, UK.....
Please help me out about the operation of this ckt.
cheers
Coffin
Ignorance and self-centered are the epidemics of human.
Old 3rd February 2006, 03:51 AM   #2
coffin's Avatar
Hi
NO one heard this?
coffin
Old 3rd February 2006, 04:01 AM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I think this circuit has a lot in common with the (in)famous Quad current dumping principle.
The bottom output device is actually driving the top output device and thus it never stops conducting. However, the zero current crossing glitch as seen by the input stage may be actually worse in these circuits than in a properly biased conventional class B or AB one.
Old 4th February 2006, 12:49 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Hi,try to look on the old"Audio Technique" magazine,December 1980.But if you fail to do so, I can try to email the scanned version.
Old 20th August 2009, 03:30 PM   #5
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by coffin View Post
Hi
cheers
Coffin
I have investigate the output buffer stage of this circuit and and I note an interest behavour. Especially the distortion character is of interest. It is nearly constant and don't enhance to higher frequencies. This is because the use of the capacitors C3 and C4. I think, there are for lead-lag compensation.
I have changed some resistors to higher idle current as at the original circuit. Additional I use some bjt medium power devices in parallel.
My test exemplare of this buffer amplifier topology sounded very fine; especially by midrange and high frequency aera. The disadvantage is follow: I cannot use load impedance below 16 ohms, because the distortion goes to extremly high values. Therefore I would it only use for vintage full range and midgange/tweeter speaker devices, that have high efficiency and 16 ohms impedance (diatone, supravox, auratone, PHL, glockenklang, fostex, saba and similar).
"BUF Olson BjT.pdf"
Parameter: in/out: 10Vss, R-load: 16 ohms, 100KHz sine wave, voltage gain: <1
1) Damping factor
2) Frequency Response
3) 100 KHz Fourier Analysis lin (K2: 17,5mV K3: 0,4mV)
4) 100 KHz Fourier Analysis log
5) 1MHz
6) Circuit
7) 1MHz without C3
8) Frequency Response without C3
Old 20th August 2009, 10:22 PM   #6
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Hi
NO one heard this?
Looks similar to a driver stage of my my Swinnik amp I did in mid-70'th.
Old 20th August 2009, 11:08 PM   #7
Bigun is offline Bigun  Canada
Bigun's Avatar
It looks a lot like D. Self Class XD....
Old 21st August 2009, 04:40 AM   #8
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
Eva,
an attempt for error correction. No bothersome glitches should occur, if everything works as intended (but almost certainly does not).
has anyone heard of this? composite collector load.....Hide this!Advertise here!
What is the capacitor from base to collector for? EE Solid State 11 17th September 2012 09:04 AM
Unbalance Collector Emitter voltage both pnp and npn EMX_125 Solid State 1 18th May 2010 03:30 PM
NPN negative collector resistance?? darkfenriz Parts 7 16th September 2007 05:45 PM
Open collector npn output marjan Solid State 5 15th January 2005 06:40 PM
Copyright ©1999-2017 diyAudio
