I have a pair of 35-0-35 vac (280VA) transformers, lots of heatsinks, and a wide selection of parts salvaged over the years.
I'm looking for suggestion of power amp circuit design to use to build a decent power amp. Thanks! |
#2 |
Join the Krell Klone group.
You might not be able to get to full 50w pure class-A but even 20 watt pure class-A with 100 watt class-AB will make a nice amp based on your Trafo's. I have some original Klone PCB's for the MJL devices and Mark has the Pinkmouse PCB's with TO-3 metal cans, take your pick. Join the thread.... Mark also has some extra PCB's available. More info in the Wiki...see my signature. |
#3 |
Banned
with salvaged parts you cant beat the Zen series designs at passdiy.com
enjoy the music! |
#4 |
2 * 35Vac will give about +-50Vdc PSU. With 280VA I suggest looking for 100W into 8ohm classAB amplifiers. Your PSU will support a stereo amp of 100W+100W or a monoblock 200w into 4ohm. If you really want to use up heatsinks then a high bias design might suit in which case a FET output stage as Borbely might be even better. Good luck.
regards Andrew T. |
#5 |
Hey members, 4502dude said, he has got a pair of these trafos.
So they will easly handle a 2×200W/4ohm stereo amp. Dear 6502dude! You are looking for an audiophile-hifi amp, or a general purpouse PA-amp? Regards, |
| Power Amp Design | MiiB | Solid State | 36 | 21st October 2008 06:53 PM |
| trying to design a power amp | rx7speed | Instruments and Amps | 4 | 27th November 2004 11:41 PM |
| My X-Power amp design | blu_line | Solid State | 3 | 1st February 2004 12:58 PM |
| searching for an power amp design | @fundum | Solid State | 21 | 14th October 2003 11:47 PM |
| Page generated in 0.07844 seconds (72.26% PHP - 27.74% MySQL) with 10 queries |
