Old 30th October 2002, 04:09 AM   #1
Send a message via AIM to shallenn
Default adding "main out" to my htr-5150
i need main outs on my yamaha a/v receiver. can i just "t" tap into the audio audio before the onbourd amp? has anyone done this and will i be introdusing any noise in the signal?
i would like to do this so i can use this receiver as a preamp to a pioneer m-90 amp.<---------any info on this amp will also be helpful,,,,thx, shallenn
Old 18th November 2006, 02:07 PM   #2
gni is offline gni  United States
gni's Avatar
Default Preamp outputs
Option #1
Use the headphone output. . . (or internally wire to the headphone
jack and mount output jacks. Might need some sort of L-pad or
shunt volume to adjust and match gain characteristics of both
amps. . .so volume goes up at same rate on both amps.
Option #2
Make an L-pad for direct connection to the output. (or internally
wire L-pad and mount output jacks. .
Both work well. . .
Let us know how it works.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
adding an &quot;on&quot; lamp to amp kit jayw404 Tubes / Valves 6 4th September 2007 06:52 AM
Adding diversity reception "brain" to car eRiCdWoNg Car Audio 1 10th March 2005 06:48 AM
Installing a &quot;main out&quot; in an integrated amp? driving Solid State 0 11th December 2004 10:07 PM
Adding a "Protection LED" on an amp Bricolo Solid State 24 8th June 2003 03:41 PM
Page generated in 0.07487 seconds (61.81% PHP - 38.19% MySQL) with 10 queries
