Old 19th January 2006, 04:42 AM   #1
Default Tascam PA-20B Oscillation?
Alright, so I have a Tascam PA-20B. A little tiny guy, which is what I was looking for. However, the amp is acting strange. I'm not sure if its oscillation or not. The oscilliscope sometimes shows 65mV @ 5.4MHz when the whole thing is setup but without an input signal. It also shows random things like 1.4MHz @ 5mV at times as well. The scope may not be able to catch any higher freq oscillation, 5MHz is about the max I can resolve with it. I let it sit over night on w/out an input and sometime randomly at night one channel started giving a "bad" sound so I got up and turned it off. Another odd behavior is sometimes a channel will seem to crackle and go out, and if I tap on the woofer of the speaker, it will usually come back in.
You might think this sounds like a lose wire in the speaker, but let me assure you its not. I have had this amp do the same thing on a few sets of speakers, speakers which work perfectly on a different amp. Also, when I tap the woofer, the amp is no where near the speaker to be mechanically effected by the tap.
The tascam looks to be using a chip amp of sorts inside. If anyone has some suggestions or ideas let me know. I am not familiar with the "tap the woofer to get it to work" fix but I figured someone else has encountered it before.
Thanks!
Old 19th January 2006, 06:37 AM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The crackle issue and the sound coming in and out as you tap the woofer is probably due to bad solder joints in the amplifier PCB. The oscillation issue may be also due to these bad solder joints, or due to bad decoupling capacitors, or even due to bad design...
Old 19th January 2006, 09:19 PM   #3
Thanks for the suggestions. I hadn't thought of bad solder joints but the unit is relatively old. I'll open 'er up and take a look. Hmm, a little back emf helps w/bad solder joints. . . Could be caps too, I'll check that.
The unit is probably not of the highest quality either. . . but its a nice for a little desktop amp.
Tascam CD-302 Modifications djcl.ear Digital Source 3 19th January 2011 09:23 AM
tascam cd-701 vic57 Digital Source 0 30th August 2008 11:31 AM
Tascam 688? Riker Analogue Source 0 3rd September 2007 10:08 PM
Tascam Porta 02 big jim Solid State 2 2nd July 2006 09:09 AM
Tascam 32 akersa Analogue Source 0 22nd June 2003 03:10 PM
Page generated in 1.62509 seconds (4.28% PHP - 95.72% MySQL) with 10 queries
