Hi, every one in need help regarding what ic i should use for an amp..
i have a 12v ps for my preamp... the problem is that i found ths amp ic's TDA7454, TDA7383, TDA7560,TDA7385. all of them are rated at min 18V. can this work at 12 v?
Hlp wold kindly be apprctd!!
