can you build a reciever ? cheap ?
Old 17th January 2006, 10:18 PM   #1
v1d9uy is offline v1d9uy  United States
Default can you build a reciever ? cheap ?
can a novice build a reciever ? i mean i want a heavy simple receiver but im no electical god here by any means and im not rich ...... so im not gunna blow 3-5k on some super receiver .. id consider 2-4 hundered to build one that was simple and would last a long time .. and if anything happened i could fix it .. cuz i built it ! any thoughts ? any kits ?or am im just crazy ?
Old 19th January 2006, 01:29 AM   #2
quasi is offline quasi  Australia
quasi's Avatar
Hi v1d9uy,
The tuner section worthy of any quality would be very complex and would cost maybe 2 - 5 times what you could buy a quality consumer tuner off the shelf. I would couple this to a DIY pre-amp and power amp.
I do recall seeing a kit from the 1990's that I may be able to dig out for you. It had a digital display and some basic memory functinality but the circuitry and layout are very involved. Let me know if you would like me to find it.
Cheers
Old 19th January 2006, 01:54 AM   #3
well actually i guess i could just build a preamp see i really dont care about a display ... or radio so a guess a super simple preamp would be what im looking for .. do preamps have sub output ? or would that be on the amp ? i wasnt sure about that part
Old 19th January 2006, 02:21 AM   #4
quasi's Avatar
Most pre-amp designs I have seen are for stereo. It would be easy though to add a sub-bass output using a seperate PCB. This could be contained in the same case and run off the power supply that feeds the pre-amp.
Cheers
Old 19th January 2006, 04:35 AM   #5
my main reason for this is i have a older sony str-de475 and the sub out is messing up i wiggle it and the front main speakers cut out and the sub plays at very low volume so there is something going on i did figure it was worth fixing being as how it was a $149.99 special when it wa new like 5-6 years ago
Old 27th January 2006, 11:02 AM   #6
Larry Lomax is offline Larry Lomax  United Kingdom
Larry Lomax's Avatar
Hello,
Lets analyze your question.
You want something you could be able to repair yourself. But you aren’t so good in working with electronics. And probably you have not a wide experience on radio circuits.
Let me give you a suggestion. Once upon a time, I was in your same condition. But I wanted a real superheterodina receiver for long, medium, short waves and FM. FM stereo was not yet invented.
The quest was your own. I failed, many times. I spent a lot of resources on trying. But when I decided to study, dismounting old radios and taking advice from how they where made. After reading books, bought instrumentation, and started from … one valve receiver. After many years I succeeded, I built a full superheterodina with eight tubes capable of receiving from long to short waves to FM with stereo discriminator and It was a great achieving. After that, the next was the same receiver but with transistors. And after some failures I succeeded. After that I got interested in digital electronics and started building a PC with Z80 and CP/M, it was in the late 70’s. They are all still working, computer too. But, they are all projects for a life. Like to reach a doctoral degree. They all are projects for live. No matter what difficult they builds up. And achieving a goal like this is of a very great satisfaction.
But, if you are looking for a new tuner for your stereo… Just drop it. Save money and buy a shiny new made in Taiwan, Korea o China, tuner.
Thanks for reading cheers
Larry.
Is there a kind of corrector in the forum?
I wrote "projects for a life" and it shows "projects for live" ?
Nothing happens by itself, you have to work hard to arrange things to make it happen.
Old 27th January 2006, 11:16 AM   #7
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Simple answer. Yes.
But as your pre is already broken, I suggest you try fixing that first, as it is likely from your symptoms that you just have some dry solder joints. You will need a small tipped soldering iron and some solder, not wasted money, as you will need them later if you build your own.
Unplug the unit from the mains, and open it up. Take a couple of pics, and post them here, then we can tell you what to do next.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 28th January 2006, 11:59 PM   #8
hermanv is offline hermanv  United States
Default How about a kit?
There are DIY kits, close to inventing your own, with risk and engineering decisions pretty much taken care of.
Try this link:
http://www.bottlehead.com/et/adobesp.../foreplay3.htm
This OK design has been so customized that there is almost no limit to how involved you can build it, you can spend more and add layers of audiophile magic dust or not.
Old 29th January 2006, 12:48 AM   #9
anatech is offline anatech  Canada
anatech's Avatar
Hi v1d9uy,
Your Sony may have something as simple as cracked solder connections where the jacks are soldered to the PC board.
Patience, soldering iron and solder. Take your time. Don't add too much solder to the joints.
Use your eyes and your head.
-Chris
can you build a reciever ? cheap ?Hide this!Advertise here!
Cheap simple class D amp circuit to build. guitar_joe Class D 264 24th June 2016 02:24 AM
Cheap Subwoofer build for less than £150 llyrroberts Subwoofers 10 26th January 2009 10:35 AM
Build a Loud, Simple & Cheap amp for a friend EWorkshop1708 Car Audio 5 19th April 2008 05:53 PM
Another Goldwood OB Build... REALLY CHEAP saabracer23 Multi-Way 4 16th April 2008 06:05 PM
Help needed to build a FM Reciever?? RMS Everything Else 5 27th June 2007 04:43 PM
Copyright ©1999-2017 diyAudio
