This is probably a newbie quetion, but I never understood why:
How come many class AB or Class B solid state amps that use BJTs for their output stages use discrete-built Darlingtons (sometimes upwards to three - two driver pairs and then the output pair) as opposed to fabricated Darlington transistors (the ones that have two transistors in one package)? I know that fabricated Darlingtons have lower transition frequencies, but I would *think* that making a discrete pair would also have a low ft... |
#2 |
Search for the recent thread that discussed this same Q.
You did search??
regards Andrew T. |
#3 |
Discrete components allow Class A drivers and more robust (SOA) parts in general; packaged Darlingtons are usually hard-wired so one is locked into the classic configuration and that limits design choices and
flexibility. Some designs such as the Leach amplifier use a triple Darlington configuration. I don't know of any packaged devices like that. I've never seen a Sziklai/compound-complementary device either. Ft varies, but there are plenty of audio power devices that go up to 30 Mhz or so, and drivers that go even higher. I think there have been some hybrid packages that contain a full output stage, but that locks one into the choice of devices and usually a considerable limit on output power. Onsemi may have a good idea in packaging a thermal diode with an output device, even though the device is pricey and requires a 5 pin package with a non-standard pinout array. |
#4 |
Electrons are yellow and more is better!
Besides what Damon says you can also take into account: What does the "market" need? This is usually the industry. If the industry demanded faster Darlingtons the manufactures would also provide it.
/Per-Anders (my first name) or P-A as my friends call me |
#5 |
What if the pre-packaged darlington doesn't have the specifications wanted?
Using discretes allows for a greater selection of parts parameters. There are simply more discretes to choose from. |
#6 |
Exactly. In the years past I have tried several darlington packages and just about the only one I had good success with were the MJ11015 and 11016, and even then just for relatively low supply rail voltage (SOA is not too good).
| Topologies using darlingtons. | beppe61 | Solid State | 71 | 13th January 2011 11:27 PM |
| Darlingtons vs. FET's | valterdaw | Car Audio | 14 | 6th June 2007 04:13 PM |
| Page generated in 0.07631 seconds (73.82% PHP - 26.18% MySQL) with 10 queries |
