diyAudio Moderator Emeritus
Does anyone has an idea of output stage that has gain G=1? Not 0.99, not 0.9, not 1.1, but exactly 1?
Something like Hawksford EC or NP-PMA, but with minimal component. I'm looking for simple EC (2 transistors maybe), that this 2 transistors can be used for setting bias, also for local Error Correction that gives G=1 exactly. |
#2 |
The Threshold S-300 schematic (Nelson Pass) is around here somewhere. No gloabal feedback, sounds great.
#3 |
Hi, DJK,
Thank you. I'm looking for somekind of "Local Error Correction" that can be implemented in low biased classAB (bias below 50mA). It is to be put on global feedback. |
#4 |
Banned
lumanauw
Does anyone has an idea of output stage that has gain G=1? Not 0.99, not 0.9, not 1.1, but exactly 1? Something like Hawksford EC or NP-PMA, but with minimal component. I'm looking for simple EC (2 transistors maybe), that this 2 transistors can be used for setting bias, also for local Error Correction that gives G=1 exactly. ---------------------------------------------------------- ZEN series |
#5 |
It can't always have exactly unity gain since there is not such a thing as a zero output impedance. Error correction just puts one or two more nines into the decimal part of the gain figure.
#6 | |
What difference does it make, if gain is 0.98 0.99 or 1.02 as long as it is constant.
lineup |
#7 |
Hi, EVA,
Sometime ago, I remember that you opinioned that what is called "Error Correction" is not clear, because the whole audio amp system is an EC itself I wanted to make a "local" EC around output stage, so it can level input and output of that EC output stage as close as it can get to G=1, in order to make the work of the differential is much light-er. If the differential pair works light-er, I feel that the sonics is better. Something in the spirit of "making the elements as linear as possible before applying feedback", so the differential pair will work much light-er (not burdened by the total mess of the whole amp) |
#8 |
Then add another differential to the output stage
#9 |
Jarek |
#10 | |
But trying to make with those always result in NP-PMA or Hawksford EC. Do you have any ide to make output stage with "differential" to control input=output, that can follow full swing from +rail to -rail with G=1? Hi, Jarek, Thanks. I will study it. |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| preamp output stage resistor from output to V- ? ? | Bernhard | Solid State | 4 | 19th October 2007 02:55 PM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| TV Horzontal Output Transistor for output stage..? | ronybc | Solid State | 46 | 10th October 2005 02:26 AM |
| Page generated in 0.09679 seconds (85.01% PHP - 14.99% MySQL) with 10 queries |
