Old 16th January 2006, 01:06 PM   #11
klitgt is offline klitgt  Denmark
klitgt's Avatar
Originally posted by pinkmouse
Common ground first.
Sorry, I suffer from a cold that may block my ability to understand. Could you explain what you mean?
Old 16th January 2006, 01:11 PM   #12
klitgt's Avatar
Originally posted by Christer
There are fairly cheap insulated and gold plated ones too, if one can only find the right place to buy them. There is what seems to be a generic type that is sold around the world, but prices vary. Here in Sweden I can buy a pair of two for less than 3 € at BilTema, while Elfa used to sell them for about twice that price for a single one. BilTema seems only to have two stores in Denmark (Aalborg and Naestved), but I am sure there are other companies selling them too. I have seen exactly tha same type on many photos of equipment on this forum from around the world.
http://www.biltema.se/products/produ...?iItemId=78714
Hm, and now when I checked them up to provide the link, I see they now look a little bit different from the ones I have bought earlier, but they are still isolated and gold-plated.
Correct, this type is for sale everywhere. But beware! Most of them do not have a fixed center pin. It rotates with the RCA plug you may rotate to get it in or out, and imagine what happens to the wire soldered at the inside og the enclosure.
So before you buy make sure they have a fixed center pin!
Old 16th January 2006, 01:17 PM   #13
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by klitgt
The RCA sockets in my project are all but one isolated from the enclosure.
My last question was whether this wire should go to the PSU minus pole before going to the common PCB ground point, OR go from the jack-sleeves directly to the common PCB ground point and then onwards to the PSU minus pole as a "dead end"?
Most used solution is separate pin at amp input at PCB.
At this is connected.:
input signal ground+potentiometer ground+amp input resistor ground
From this ground goes a track to PCB common ground = power supply ground connection.
To make connection to PCB common ground is possible, too.
And, not often but sometimes, making all ground connections directly to power supply capacitors negative is used.
lineup
Old 16th January 2006, 01:22 PM   #14
pinkmouse's Avatar
You said:
...OR go from the jack-sleeves directly to the common PCB ground point and then onwards to the PSU minus pole as a "dead end"?
Make sense now?
In your terminology, all ground runs should be "dead ends" where possible.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 16th January 2006, 01:22 PM   #15
klitgt's Avatar
Hi lineup, just one thing that may confuse you (and others): I run a +/- PSU, not a +/0/- PSU, the latter always has 0 as ground. My PSU has - (minus) going to ground.
Old 16th January 2006, 01:26 PM   #16
klitgt's Avatar
You said:
Then I said:
Make sense now?
Thank you, now I understand everything perfectly!
Old 16th January 2006, 04:21 PM   #17
Lovan is offline Lovan  Sweden
Lovan's Avatar
Send a message via ICQ to Lovan
I have no idea why they are using that picture since they are still selling the version with white washers(I presume that's what you were refering to). Have got quite a lot of those in my bin. Somehow I doubt they are good sound though...
Old 16th January 2006, 04:37 PM   #18
White washsers, yes, that's the ones I was referring to, and I am also quite sure i had a look in those shelves and saw them as late as just a few days before Christmas. As far as I can tell they are identical to the ones Elfa used to have at a much higher price. They are hardly very high quality, considering the low price, and that they seem to show up here and there, all over the world, usually relabelled with the brand of the company selling them.
Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... EchoWars Solid State 37 3rd August 2008 09:50 AM
Optimal grounding? Skorpio Solid State 2 14th November 2007 09:43 AM
Optimal Techno sub... theimperia Subwoofers 8 21st May 2005 07:26 PM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 10:27 PM
Optimal snubbers jackinnj Solid State 7 19th January 2005 01:13 AM
Page generated in 0.10351 seconds (86.77% PHP - 13.23% MySQL) with 11 queries
