diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   100dB (http://www.diyaudio.com/forums/solid-state/71862-100db.html)
nbcd 16th January 2006 08:56 AM
100dB
hy all.
Can someone please explain me what it means this -100dB inscription on my sound card? I know that dB is a measure unit for noise but why is it negative.
thanks.
Best regards!
peranders 16th January 2006 09:10 AM
It means probably that the noise and distortion level is 100 dB under full output voltage (0.001%).
myhrrhleine 16th January 2006 06:57 PM
>I know that dB is a measure unit for noise.
Actually, dB refers to a power ratio, logarithmically expressed.
It compares one thing to another.
In this case a minus would indicate that something is 100dB less than something else.
jacco vermeulen 16th January 2006 07:06 PM
Aaah, i get it !
You mean 20Log( 1/ 100.000 )= -100dB
Welcome, Lady Merlin.
AndrewT 17th January 2006 07:44 AM
I do hate the confusion caused by the difference in the British and continental way of using , & . to indicate the decimal point and grouping large numbers into 10^3.
100,000.0 (GB) = 100.000,0 (Rotterdam) =10^5(unconventional but understood)
Give us a solution that works world wide.
No, don't suggest we revert to imperial measure (using 1/12, ounces and pints) to match the old fogies across the pond.
jacco vermeulen 17th January 2006 07:53 AM
www.ex.ac.uk/cimt/dictunit/dictunit.htm#prefixes
Resources saved on this page: MySQL 18.75%
