Changing 220v internal amp into 110v? - diyAudio
Old 12th January 2006, 09:26 PM   #1
rubo is offline rubo  Canada
Default Changing 220v internal amp into 110v?
Hi, i'm new here and have absolutely no knowledge regarding speaker design. I don't know if this relates to this forum or not, but i read few pots her and ther and looks like you guys know enough to start your own speaker manufactoring companies. So here are my questions.
I found two pairs of spekars one is Spendor SA350 2-way active, the other one is Klein+Hummel O-98 3-way, active as well. Both are made only to work under 220v. My question is how easy it will be to convert internal amps into 110v? And will it be worth it? My second choice is to use step down transformers, but I don't know how it will effect the performance of internal amps? I'm unable to get and schematics for those speakers, both are discontinued models.
Thanks, Boris
Old 12th January 2006, 10:47 PM   #2
AndrewT is online now AndrewT  Scotland
disconnect from the mains and open up to see the mains transformer.
Identify if the transformer has two primary windings or just one.
If only one then it is for 220Vac to 240Vac only.
If two primaries, then connecting them in series. This gives a 220Vac to 240Vac transformer.
Connecting them in parallel will give you a 110Vac to 120Vac transformer.
Be carefull when connecting a two primary transformer to keep the windings in phase or you could damage the transformer before the mains fuse blows.
regards Andrew T.
Sent from my desktop computer using a keyboard
110v or 220v, how can you tell? fjmart134 Tubes / Valves 2 8th June 2009 10:18 PM
VELODYNE 110V to 220V iblieve Power Supplies 1 11th May 2009 07:25 PM
AR XA 220V to 110V dan duette Analogue Source 2 13th February 2009 01:08 PM
How to convert 220V to 110V??? Real Prober Digital Source 4 5th November 2004 07:02 AM
Help: conversion from 110v to 220v Russell Sit Solid State 13 5th December 2002 08:28 AM
Copyright 1999-2017 diyAudio
