Old 12th January 2006, 05:32 PM   #1
Default Yamaha RX-V650 AV Amp No Output From Front Right Speaker
Hi, I have a Yamaha RX-V650 amp with no output from the front right speaker. All other speakers are fine.
I have swapped the speaker and the cable.
I have also moved both front speakers from the "A" output to the "B" output, with the same results.
Can anyone point me in the right direction please?
I have searched for schematics online but cannot find any.
Thanks.
Old 12th January 2006, 07:34 PM   #2
Fidelity Audio's Avatar
I would check the muting relay , they have been known to carbon up on the contacts.
The left and right channel will share the same relay, so at least you know its switching.
Also check for dry joints on the output binding posts, these may have dry jointed on the pcb.
Old 13th January 2006, 07:39 PM   #3
XEAGLEKEEPER's Avatar
I have a service manual for a RX-V630/730. Does your unit have a test function on the remote? If so , connect all speakers ,power up unit and press the test button you should get a test tone from each speaker one at a time LF,RF,LR,RR,CTR AND SUB ( not necessarily in that order) .. If there is no test feature check to see if you dont just have a dirty source input connection or possibly dirty selector switch,or volume control.
Old 13th January 2006, 10:01 PM   #4
I've had it apart today, resoldered the joints on the output binding posts.
How do I check the relay? I was going to replace it but can't locate where to buy one from.
Couldn't see anything obviously faulty (burnt etc.)
Old 13th January 2006, 10:01 PM   #5
Yes, there is a test function, there's no test tone from the front right, a test tone is audible on all of the others.
The auto setup also fails saying no front right speaker.
Are there any specific parts in your service manual that you think I should check please? I'm hoping the rx-v650 is quite similar!
Old 17th January 2006, 02:05 AM   #6
o.k. on the v730/630 Q7-Q10 should have around +/- 44-45 vdc on the collectors these are the amp output transisters for right front . should be 1.0vdc or less on the emitters and bases. also relay 102 is for left&right front ( RLY102).
Old 17th January 2006, 02:05 AM   #7
I purchased my service manual at Yamaha.com.
Cheers Dave
Old 17th January 2006, 08:06 AM   #8
Thanks very much, I'll take a look.
Thanks for the service manual info too.
Old 18th January 2006, 01:22 AM   #9
Banned
"The auto setup also fails saying no front right speaker."
sounds like syscon fault is this a receiver?
Old 23rd August 2006, 09:25 PM   #10
Thanks for everybody's help, I've finally got around to taking it apart again and think I've found the problem by measuring the voltages on each component in the circuit (working back from the posts) and comparing to the equivalent component on the front left circuit with the help of the circuit diagram. I used a mono sound source.
There seems to be a faulty transistor (hugely different readings), the problem is I cannot find an equivalent anywhere.
The original transistor is a 2N5551C-AT but I can only find a 2N5551. The supplier that sells it (www.maplins.co.uk part no. UL36P) cannot find any spec sheets for the original either.
Can anybody help with regard to the suitability please?
Many thanks,
Alan.
FS: Yamaha RX-V650 7.1 Home Theater Receiver wigginjs Swap Meet 2 31st August 2009 11:25 AM
HK 'Deuce front end on G2 drive output stage? GordonW Tubes / Valves 0 9th June 2008 02:22 PM
A75 front-end unwanted output signal ckwong99 Pass Labs 1 29th December 2007 09:28 PM
Crest V650 Power Amp hooha Swap Meet 1 13th December 2006 05:46 PM
Looking for Technics schematic SU V650 Orgonom Solid State 5 20th April 2004 09:45 PM
Page generated in 0.13075 seconds (71.62% PHP - 28.38% MySQL) with 10 queries
