#632 |
Is there anyone out there who knows which of these thermaltrak transistors used by McIntosh Mc2kW ?..or which these can be an equivalent Output..thanks
NJL0302DG 180W NPN NJL0281DG 180w PNP NJL3281D 200W PNP NJL1302D 200W NPN NJL4302DG 250W NPN NJL4281DG 250W PNP NJL21193DG 200W PNP NJL21194DG 200W NPN |
#633 |
NJL1302/NJL3281 (132300/132301)
Looks like Sponge Bob has killed another thread. |
#634 | |
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#635 |
Thanks Jacco, this will be my stepping stone to build the Mc2kw..I'm in the process of making the PCB..Would you mind if ask where I can find the source of this latest catalog of McIntosh Semiconductor Data? It's a good thing to have this because its difficult to interpret McIntosh house ID..
Hi Tony..I'll be calling You. |
#636 |
Hi Jacco, I'm back to you..Sorry, cant find either ECG or SK manual in hometown to search even equivalent numbers for Mc2KW transistors..I am still after for a few tr's for its preDriver stage. I have been struggling to start DIYing this amp and was nowhere to find its mcintosh house numbers. Other parts are no problem..can you provide once more?..if so, I'll post the numbers..
Thanks... |
#637 |
The MC2KW is current McIntosh production, i respect that.
Would be a different story if the amp model was discontinued.
#638 |
Thanks Jacco.
#639 |
This minute I got 5 pairs ( matched so the vendor claims ??) NJL4281D / NJL4302D at internet auction nice price but not sure what to do with it. The ultimate thermal stability
of queiscent current is still achieved by the QUAD 303 triple cascade but this has dynamic constraints. I would use the trak diodes to control the bias of a standard Vbe multiplier which is not in thermal contact with heatsink. Further at least subjectively but not measurable with software thd spectrum analyser it has turned out that to keep all of the BJTs of an amp predriver Vas drivers at a constant temperature as these are mounted on a common heatsink the temperature of which is controlled by a thermostat circuit. |
| my project: class B with ThermalTrak | mafoe | Solid State | 37 | 16th June 2009 04:30 PM |
| ThermalTrak transistor application. | Jeb-D. | Tubes / Valves | 37 | 9th May 2009 02:17 AM |
| OnSemi ThermalTrak | Arius | Solid State | 8 | 26th August 2005 04:09 PM |
| ThermalTrak circuit design | Mambo | Solid State | 4 | 12th July 2005 11:03 AM |
| Page generated in 0.10073 seconds (79.90% PHP - 20.10% MySQL) with 11 queries |
