#101 | |
Douglas |
#102 | |
I'm not saying it wouldn't work, though you are right that at least a two-transistor Vbe multiplier would be needed to avoid base current issues. My main purpose was to see if we agree that the conceptual circuit is what we should be aiming for. Douglas |
#103 | |
But as mentionned, the topology used by Leach should work like explained in the attachement. What do you think? Jean-Pierre |
#104 |
The file
JPV |
#105 | |
You do realise the current edition is the 4th edition? |
#106 |
Switching briefly to the problem of practical tests, it would be good if we could agree on a way to do them.
The method I have used in the past to plot output stage bias conditions is to deliberately underbias the amplifier by a modest amount, but enough to make sure it is always underbiased. I have used a bias setting that gave about 0.02% THD with a peak responding measurement mode. The AP System-1 can plot THD against time and this effectively gives a plot of bias conditions against time. (see p379 in the Fourth edition of the Audio Power Amplifier book) Do people agree that this is a valid method? Douglas |
#107 |
What is the dV/dI (maybe called dynamic resistance or something) of the diodes at that current?
If it is big then diverting current with resistors will decrease the temperature coefficient instead of increasing it! I didn't do the calculations though so I'm not saying it won't work, but have it in mind. |
#108 |
From the article Silcion Chip Sept 08
http://www.siliconchip.com.au/cms/A_...ntArticle.html the voltage accross the diodes appears to be .5v which is more of the schottky performance. Also,see related performance graphs for a further statrting point in the discussion, from some one who has built a unit and measured the responses as well a having a dose of the big brown smoke, yes the journalists not myself. alfred |
#109 |
Hey guys! I thought the thermaltrak devices were designed
to allow for simpler layouts. Post 99 onwards shows an exercise in more advanced tempco circuit considerations. The ultra LD amp seems to be a classic "blameless" with T-trak diodes used as Vbias (simple). Looking at the board layout would this not add alot of extra traces/capacitances to the design? (oscillations/puffs of brown smoke..? drugs or blown op's??). I,m using 2 pair NJW0281/0302 (which is equivalant to these t-traks minus the diodes) with short 4cm leads to the Vbe. (like the aska lifeforce)...rock stable. The T-trak OP stage using the Leach Vbe seems to be the best way to go. BTW.. Mr. self , If I was to give back to the community an amp based heavily on your "Blameless" design would you approve.? OS |
#110 | |
No operating the diode at another current will change the Vd of course and more if the dV/dI is high at the operating point. But at a fixed operating current in the diode this will be a fixed Vd for which the Vbe multiplier will be adjusted. Now, if the temperature changes, the Vd will drift for the tempco at that current and so the Vbias. Of course the Vd changing with temperature, the current in the diode changes so the tempco but this is a negligible effect because the proportionnal change in current in the diode due to Vd drift is equal to that drift. This is about 30% for the full range of temperature. This is a low change in tempco because the tempco changes logaritmically with the current. JPV |
| my project: class B with ThermalTrak | mafoe | Solid State | 37 | 16th June 2009 04:30 PM |
| ThermalTrak transistor application. | Jeb-D. | Tubes / Valves | 37 | 9th May 2009 02:17 AM |
| OnSemi ThermalTrak | Arius | Solid State | 8 | 26th August 2005 04:09 PM |
| ThermalTrak circuit design | Mambo | Solid State | 4 | 12th July 2005 11:03 AM |
| Page generated in 0.20062 seconds (55.81% PHP - 44.19% MySQL) with 11 queries |
