Old 16th January 2006, 03:10 PM   #21
lineup is offline lineup  Sweden
lineup's Avatar
This is the reason you should always
8 Ohm non-inductive non-capacitance LOAD Resistor
when you produce your simulations, graphs and specifications.
Amplifier will plain and simple work much better and
you will get good results and specs in your design
if you avoid loudspeakers.
Should be told in user manual of amplifier:
'Loudspeakers are not recommended,
because this amplifier was created without.
Best performance you get from using our highgrade 8 Ohm LOAD Power Resistors.'
Original signature by lineup
When you can tell sound from FFT Analyse Graph ... go sell your loudspeakers
lineup
Old 16th January 2006, 04:10 PM   #22
Darksog is offline Darksog  Finland
ok well i decide to use irfp250 200V 0.073 OHM 33A
and drop voltage + - 70v... and 6 fets and i think this is 2 ohm stabel i gointo bridge this amp and speager is 4ohm...
Old 16th January 2006, 04:10 PM   #23
now its lockked i use irfp250 Because i get it those from junked electroniks i have now 29 x irfp250 =)
Old 16th January 2006, 09:59 PM   #24
quasi is offline quasi  Australia
quasi's Avatar
Hi Darksog,
Please look at the chart here http://www.diyaudio.com/forums/showt...32#post794932. With 70v rails and a 2 ohm load 6 x IRFP250 (3 per rail) will quickly die.
Cheers
Old 17th January 2006, 02:41 PM   #25
Hi quasi
do you mean that i should use 4 fets per rail or drop voltage?
thanks
Old 18th January 2006, 01:43 AM   #26
Workhorse's Avatar
You need at least 12 IRFP250 Fets to Play Safe.........
K a n w a r
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 18th January 2006, 02:17 AM   #27
quasi's Avatar
Hi Darksog,
You can choose whether to drop the rails or increase the FETS. The chart I posted can guide you. The chart shows you that for this amp PCB, 70 volt rails and 2 ohms is not recommended. If you can make them fit, go by Kanwar's suggestion and use 12.
Cheers
Schematic: Audio Innovations, The first audio amplifier maartentje Tubes / Valves 22 25th February 2010 06:34 AM
Audio Amplifier wkahc Introductions 1 31st August 2007 06:01 PM
Car audio Amplifier willo Car Audio 12 26th October 2005 03:58 PM
Audio Amplifier Help pls silverferro Everything Else 0 26th August 2004 10:15 AM
audio amplifier mephisto Car Audio 2 21st January 2004 04:52 AM
Copyright ©1999-2013 diyAudio
