Comparator vs. OpAmp: pros & cons?
Old 5th February 2006, 07:53 AM   #51
clem_o is offline clem_o  Philippines
Hi peranders,
Agreed if you want to trigger on the basis that the input signal may be going "up" or "down" compared to reference "no signal", you'd definitely need two. But if you assume that 'eventually' the signal (since it's an AC, even often assymetric) will cross-over to the other polarity and trigger, wouldn't it be OK to do it with just one?
What I find messy is to get a time constant of 4sec with just one comparator - sounds like a job for high-capacitance with positive feedback on the reference voltage of the comparator....
Comparator vs. OpAmp: pros & cons?Hide this!Advertise here!
pros/cons of a 845 VS 211 jarthel Tubes / Valves 2 18th June 2007 12:57 PM
TL vs MLTL, pros and cons Tomac Multi-Way 5 29th December 2004 12:55 PM
Filterless DAC - pros and cons? mr_push_pull Digital Source 1 11th August 2004 02:56 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 05:37 PM
