Old 10th January 2006, 10:01 AM   #1
boxedin is offline boxedin  Canada
Default Single ended classA with dual supply rails
hi all,
Is there a schematic for single ended Class A with dual supply rails?.
Let me know.
Alexk
Don't read too much into my circuits unless i specify its final circuit. It is work in progress.
Old 10th January 2006, 10:11 AM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
One of the most popular is the AlephX. You really have to come over to passlabs forum.
/Hugo
Old 10th January 2006, 10:17 AM   #3
pinkmouse's Avatar
Or stay here and look at the Krell Clone thread. It's not single ended but it is a cracking amp.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 10th January 2006, 06:41 PM   #4
How much power are you talking about? The original JLH design was redesigned about 1996 for dual supplies, as well as Rod Elliots versions. And then, there are the versions at Nelson Pass's DIY site.
Check 'em out.
http://www.tcaas.btinternet.co.uk/index-1.htm
http://sound.westhost.com/projects-1.htm
http://www.passdiy.com/default.htm
Old 10th January 2006, 07:31 PM   #5
gl is offline gl  United States
And let's not forget the Alephs on the passlabs site.
Graeme
Old 10th January 2006, 07:34 PM   #6
I forgot to metion i need a circuit based on bjt single ended with dual power supply rails.
PAsslabs are FET based.
Old 10th January 2006, 07:37 PM   #7
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
on one of the passlabs sites is a project from 1977 that sounds like it matches your needs. it's an project from the now defunct "Audio" magazine. the entire article is available as a pdf.
mlloyd1
edit: i found the link:
link to single ended class a amp
Old 10th January 2006, 07:39 PM   #8
How about the A25 on the passdiy site then.
Graeme
Old 11th January 2006, 09:42 PM   #9
That is diffrential input stage not single ended. :@
It seems like no one has buit an single ended class A amp with dual rails without feedback.
Old 11th January 2006, 10:02 PM   #10
Hi boxedin,
In my view, a single ended amplifier refers to the output stage. I realize that others may hold a differing view.
I consider the A25 to be a single ended class-A BJT amplifier. I can't think of another recommendation offhand but there must be one.
I think you may have to design up something for yourself. How about grafting the front end of the JLH onto the output stage of the A25?
Graeme
single-ended power supply (12V) based active crossover r_s_dhar Car Audio 8 15th April 2011 08:44 PM
power supply for my single ended amp jhaible Tubes / Valves 23 2nd November 2006 08:51 AM
Power supply for Single Ended Amplifier kmtang Tubes / Valves 20 27th June 2005 03:46 PM
Page generated in 0.09014 seconds (78.01% PHP - 21.99% MySQL) with 10 queries
