Hot Follower 99 - Page 3 - diyAudio
Old 9th February 2006, 05:46 PM   #21
Electrons are yellow and more is better!
peranders's Avatar
I have used diamond buffers (never seen before ) in some of my designs and I did some experimenting with higher currents. My conclusion was that it got quite unstable (the bias) with a big ratio between the driver transistor and the output transistor. 1:5 works good.
As a power unit I think this never seen design needs a bit more development.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 9th February 2006, 07:03 PM   #22
beppe61 is offline beppe61  Italy
Originally posted by peranders
1) I have used diamond buffers (never seen before ) in some of my designs and I did some experimenting with higher currents.
Dear Mr. Peranders,
1) speaking of the diamond topology I remember a headphone amp with no gain (i.e. a buffer) suitable for Grado headphones that had really impressive figures.
The idea of building a high current diamond buffer is very intriguing indeed.
That said what do you think of the power section of the attached schematic ?
It is so basic that even it seems just not possible it works!
Does it has any chance to sound good?
Thank you very much indeed.
Kind regards,
beppe
Old 10th February 2006, 12:27 AM   #23
anatech is offline anatech  Canada
anatech's Avatar
Hi P-A,
I have done a fair amount of work with power diamond buffers. Fantastic detail at low power levels. Large current excursions cause a lot of problems. No signal bias current is a problem at high driver to output ratios.
-Chris
Old 10th February 2006, 01:04 AM   #24
mtlin12 is offline mtlin12  Taiwan
mtlin12's Avatar
My Power Diamond Buffer is quite stable, and now a Taiwan Audio
company is preparing to mass product this Power Follower with
their own 10dB step-up IPT.
How about a Power Follower with an IPT?
This is their all-in-one PCB
EuLeit Audio Studio one of the best hi-end Amp design house in Taiwan http://www.euleitaudio.com
Old 7th March 2010, 08:35 PM   #25
Default Power Follower 99C
Hello
I'm in the process to give a try to the Power Follower 99C .Unfortunately I don't know how to contact to Andrea .
I do not have his E-mail address .
I have a question
On the schematic there is one 2k2 resistor and one 220R
On the layout there is two 2k2 resistor and no 220R .
I dont know which one is correct .Can someone help me lease with these problem .
Thank you very much
Greets gabor
Old 7th March 2010, 09:00 PM   #26
tiefbassuebertr's Avatar
Originally Posted by gaborbela View Post
Hello
I have a question
Thank you very much
Greets gabor
about
Audio Design Guide
I read:
Use ciuffoly@gmail.com to contact me with Windows Live Messenger to get real-time help on my projects.
and
Use webmaster@audiodesignguide.com to contact me by email to get information on my projects.
Hot follower/cool follower webercarbmann Solid State 13 2nd November 2010 03:23 PM
Need help with DC follower/peak follower HELP! gain wire Parts 4 8th July 2008 04:32 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 07:47 PM
hot follower UrSv Pass Labs 2 25th September 2002 05:49 PM
Copyright ©1999-2017 diyAudio
