#21 |
not the least thought about any jacking
to me, you are showing interest in the subject and doing good contribution: Some little reading for me and for our friend beppe61 from Italy
lineup |
#22 | |
Maybe I am quite superficial but I do not think that complexity is a guarantee for a good sound. Instead I like terms like: short signal path, few gain stages, single pair of good output devices, no current limiting circuits, ecc. Of course in some situations complexity is a must. For instance to power big speakers in big rooms we need a lot of output pairs ... But in a "normal" listening room with normally efficient speakers a beautiful simple amp can give really nice performance. Thanks again and kind regards, beppe |
#23 |
Did it Himself
Beppe, by saying better ways I did not necessarily mean more complex, nor more active parts. I'm sure my design will fit in with your ideals.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#24 |
Great and extremely nice little amp. Congratulations! I confirm you that with just a pair of TIP142/147 devices it is possible to get very good sound as in the Albarry design. When we opened one of these monos we could see: 1) very big toroidal for a 45W/8 ohm amp (a about 400VA very nice toroid from ILP, UK) 2) two big filter caps of the screw terminals type I think that the secret of its clean and powerful sound could be this very powerful power supply and the lack of current limiting devices/circuits that can harm the dynamic response. Anyway, could you give us some more details of your excellent amp? Voltage rails, voltage gain, input impedance, what kind of protection have you chosen (very important point for me). It looks very very well done. And very cute also. Please keep us informed on this 3D. Thanks a lot and kind regards, beppe P.S. and the next maybe "final" step would be to replace the output pair for a pair of mighty Sankens darlingtons in order to get a dynamite little monster. I understand that Sanken are the best for linearity and ability to deliver clean current to loads. If I am not wrong they can source more than 10A and give a prodigious response. Nevertheless I can testimony that just a single pair of TIP142/147 can give an enough astonishing sound. |
#25 | |
Please give us more details. Thanks again and kind regards, beppe |
#26 |
Did it Himself
This is the prototype schematic, note that it's design and/or components values may be subject to change once testing is complete.
Ignore the transistor types, they are just what models I have in the schematic program. 2N5401 is used in the input stage and ZTX653/753 in the voltage amplifier stage. ![]() Sanken devices could be used, but to gain the best results, i.e. take advantage of the increased speed, the compensation may need to be adjusted a little. As you can see no protection other than rail fuses is implemented. I think this gives best dynamic response. The amp is designed such that if either of the rail fuses blows, the amp shuts down immediately so there is no way that there will be a bad DC output fault. Input impedance is approximately 35k, voltage gain is approx 27 from input to output. PSU is 25 volt transformer.
| Schematic: Audio Innovations, The first audio amplifier | maartentje | Tubes / Valves | 22 | 25th February 2010 06:34 AM |
| My OLD Project....... cheap tube audio project!!! | tube-lover | Tubes / Valves | 4 | 8th May 2008 09:26 PM |
| Audio Amplifier Project question | Thisisme | Solid State | 18 | 20th November 2007 01:24 AM |
| Audio amplifier project kits | syber | Chip Amps | 2 | 6th December 2006 07:42 PM |
| Amplifier Project | ManUtd | Solid State | 2 | 3rd November 2003 05:00 PM |
