#6921 | ||
Banned
#6922 | |
What challenge? It sounds as if you misread what I said. I’m talking about complete front-end designs here, not just the input long tail pairs which are only a part. I’ve done plenty of sims that confirm that a fully symmetrical front end can be made just as fast and just as linear as any asymmetrical design. And no, I don’t like jfets for differential long tail pair inputs unless a CMCL (see Edmonds stuff) is used to steer the VAS biasing, allowing high impedance LTP loads. Their gm is just too low for adequate (in my eyes) gain and linearity otherwise. |
#6923 |
I personally don't care what you like or don't like. I use complementary fet input stages and I have used them for the last 35 years or so. You can do what you like, but it is unprofessional to criticize the work of another professional without evidence or proof. I suspect that my circuits will easily compete with yours, the only real difference will be the final application and my circuits might be less complex, yet more sophisticated.
For example, if you talk about high power, I made a 2000W power amp back in 1969 with airblown heatsinks, but it would be impractical for audio. I now make a fully rated 800W into 4 ohm amplifier that is for sale across the world. I could easily turn it into a 2500W amplifier with a bridge design and fans. No big problem, and it would have a slew rate greater than 100V/us easily. I have been doing this for decades. The only thing that really changes with time is that the output devices get better and stronger, and I use the best that we can find. What brings you or anyone to impugn my efforts? Why? Are there not other threads where you can show your competence? |
#6924 |
Andy C, you are misinformed. I have used circuit emulation for the last 42 years. Yes, I even modeled the germanium 2n1305, myself with a semiconductor curve tracer in 1966. We found probems with emulation, even then, than made me a little shy of using ANY circuit analysis program. I am old enough to have finished college without needing a computer, or even a calculator to do the coursework. This is both a blessing and a curse, but I can do more without a computer than many can do with a computer, because of this.
In 1970 I took several courses in linear engineering from 'the father of SPICE', Don Pederson Look him up, if you don't believe me. He was one of the best professor's that I ever studied under, but his class notes were mostly hand derived, not computer simulated, and I have them still in my possession. In those days, computer derived distortion was a rough approximation, and the models were VERY complex. I tried and failed in 1973 to get a good SPICE simulation on the UCB computer of one of my fet circuits, so I let it go. Today, 35 years later, perhaps things have caught up, and certain individuals who possess very high talent and standards might be able to emulate circuits pretty well. That is why I trust PMA to do generic comparisons on his SPICE emulation. I can't do that well as yet, so I just do it the old fashioned way. I build it, and then test it. Is this so difficult for you to understand? My comment: 'I don't need no stinkin' SPICE' still stands, I don't need it, but it can be useful on occasion. Doesn't that make sense to you? |
#6925 | |
What on earth are you going on about? I prefer not to use dual jfets in preference to dual BJT's for a specific application (LTP's without a high impedance drain load) and I gave the reason why. Why is that so offensive? |
#6926 | |
Just one point to remind - the simulations on JFET circuit resulted in simulations of balanced input / balanced output topology. The simulations of my BJT preamp, and the measurement shown as well, is performed on a single-ended input / single ended output circuit, though complementary-differential. It makes difference, especially in the spectral contents. |
#6927 | |
Glen is NOT incorrect. If you read his post more carefully, you will see he is talking about long tailed pairs. Regarding the input (and, for the moment, neglecting the consequences for the rest of the circuit), adding a complementary LTP is pointless, except that two times more output current is available and a bit less noise. Using D. Self's words: "you cannot balance a stage that is already balanced". BUT.... looking at Pavel's experiments, I suppose you are talking about a different kind of input stage, something like J1...J4 in the figure below. Opposed to the second input stage (J5...J8) the first one does NOT contain LTPs, which makes a distinct difference in distortion. In this respect you are right. I've repeated Pavel's simulations in a slightly different (and more meaningful!) way, that is, keeping the standing drain currents exactly the same (and of course the output currents too, 2mApk-pk). Now we see that 3rd harmonic is halved compared to the true complementary LTP stage. BTW, In Pavel's simulating, the drain current of the latter was only half as large. Therefore, the 3rd harmonic was much higher. I hope I've removed most of the confusion. Regards, Edmond.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#6928 |
Hi Edmond,
you've lost me. Why does the first (J1 to J4) not contain LTPs? But the second (J5 to J6), which has the same connections, contains two LTPs? |
#6929 | |
Simply, because the sources are not connected to a constant current source. IOW, they are pairs without tail. ![]() Cheers, Edmond.
#6930 |
are you saying that the 2*9.28mA in the first diagram is not constant? whereas the same current shown as I1 IS HELD CONSTANT. |
