#5001 | |
You mean those 'lumped parameter' guys? I have no comment.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge. "Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti |
#5002 | |
I work for a company that probably uses your equipment. I'm also familiar with the applications. I just figure that building an enclosure that will hold a nitrogen purge with readily available connectors and mountings would be an interesting challenge.What type of equipment does your company build? I'm a sensor applications engineer and work in etch, films, cmp, wets... (diffusion, the backend, the list goes on.) Regards, Mike.
"We are all agreed that your theory is crazy. The question which divides us is whether it is crazy enough to have a chance of being correct. " Niels Bohr |
#5003 |
This is inappropriate. All you need is STILL AIR. It is good enough.
#5004 | |
I agree on the still air approach. Mike.
#5005 | |
2012, our time is running out. |
#5006 |
Go for it Scott. However, most parts are designed for dry, clean air. That should be adequate. However a relay is a different sort of component and needs an even better environment. Perhaps you should brush up on your engineering, before trying to set me up.
#5007 | |
The air in most places is anything but clean and dry BTW.
#5008 |
It might, why don't you try it?
#5009 | ||||
#5010 |
But alas it can be heard! (Just not in any credible test.) There's a $1 million prize out there somewhere, I'm sure it could be extended to cover the same cable in both cryo and non-cryo form.
The cable guy backed down, I hear. I figure there will never EVER be a test on neutral ground of any of these claims. I predict that BOTH sides will never agree to a test of these issues where there is a real possiblity that either will be proven wrong.
| Page generated in 0.24745 seconds (64.85% PHP - 35.15% MySQL) with 11 queries |
