#3871 |
How do you manage gain (without global negative feedback) and fet input overload in such a configuration
Richard Perez |
#3872 |
Please don't complicate, yet. Richard Later, we can do that.
#3873 |
Ok John
![]() I am trying to find a suitable small floating voltage source (150 mV) maybe a schottky ? 5819 or the like.
Richard Perez |
#3874 |
PMA, if we could have a floating 50mV voltage source in place of the short, we should be near optimum. We might need slightly more voltage, but this would be a good start.
#3875 |
Please stay aside, Richard, until we get this resolved.
#3876 |
Everyone, PMA's link is now working. It is very interesting to compare the various configurations. Once we get the baseline right, then major changes can be added to see the overall effect. Richard, your input is valuable, but just let us get this baseline nailed down first. The only idealistic limitation that I see at this time is controlling what would normally be controlled by Idss. An added 50-75mV floating voltage source should do that.
Of course, other inputs are welcome. |
#3877 |
Floating voltage (between upper and lower circuit) - it works, but with higher voltage (1V), and smaller resistor (1 ohm or nothing). It controls Id and keeps low distortion. I will be back in an hour or two.
#3878 |
Diode works ...
#3879 |
But, what is the current, now? PMA?
#3880 |
Now the current is 22mA. It is all a game of JFET threshold voltage, Vdiode (or voltage source).
Also, distortion depends on JFET grade (BL, V, GR). Maybe I could make a comparison and add to a current web page article. We have pretty nice result with 2 diodes (9.5mA). Resulting dI(outdif)/dV(indif) is 1mA/7mV. |
| Page generated in 0.24250 seconds (63.10% PHP - 36.90% MySQL) with 11 queries |
