Closed Thread
Old 8th April 2008, 07:49 PM   #3851
syn08 is offline syn08  Canada
Originally posted by john curl
Syn08, my assocate did come back with a slightly different set of equations. The problem is to interpret them into real world (even if idealized) devices.
So far I have:
single device: H2 = b2/b1 = 1/4 Via/(Vgg-Vt) (I was advised to make Vt = 1 for convenience).
diff, devices H3 = b3/b1 = 1/32 [Via/(Vgg-Vt)] squared.
You have most probably said just as much in your equations, thus far.
Unfortunately it is still difficult to compare the two distortions at this point as one is controlled by square law.
However, to just equate them, and find a reference point might be interesting, as it would show where on the operating point that the 2'd harmonic of a single fet would equal the 3rd harmonic of an ideal diff pair.
Then we might put in realistic lambda for the fets and note the difference.
After, we might try resistive degeneration, much like PMA has already started.
Finally, we might find what complementary differential fet input does and how the two fet pairs interact, and if there is an ideal operation point or condition for best overall distortion, especially maintaining lower order and minimizing higher order, such as 5th and especially 7th.
I do have the class notes that my associate sent me, if you want me to forward them. They are only a few pages, and some of what I got was from Don Pederson's book was well.
My coefficients were exactly half of your associate's, and that's most likely because of a confusion with the bias source value (Io vs. 2*Io).
But anyway, as you probably noticed, the ratio between the single ended H2 and the differential H3 is a constant (for the non-degenerated stages, devices with parabolic models). Therefore, I don't think there's here a sweet spot in this single ended vs. diff game. In this sense, the ratio of H2 to H3 is kinda "best case".
As Klaus also mentioned, for a particular JFET model, biasing and keeping the excursion as small as possible and only in the parabolic region (so avoid the places where lambda matters) are the only ways I can think of in decreasing the distortions, both for single ended and for diff stages. Whatever way you are crossing this region (Vgs or Vds) you only add more distortions to both single ended and diff stages outputs.
Old 8th April 2008, 08:05 PM   #3852
There is more to this. For example, what if we made a complementary folded cascode single sided design, rather than a differential complementary folded cascode design?
What happens when vacuum tubes are used differentially?
What about REAL FETS?
We know that real fets have some channel length modulation. Is the third generated by this process additive or subtractive to the third generated by differential operation?
You see, there are many questions that now can be addressed.
Actually, at this point, it might be that simulation would give us faster and easier answers. PMA may have to lead the discussion at this point, with his simulations.
Old 8th April 2008, 08:24 PM   #3853
PMA is offline PMA  Europe
PMA's Avatar
This is a very interesting task. However, due to different time zone here and lot of work I am quite tired this evening. I will take a break and continue tomorrow, I am sure that simulation will give us some interesting answers again.
Old 8th April 2008, 08:36 PM   #3854
Thanks PMA.
Old 8th April 2008, 09:59 PM   #3855
The one and only
Nelson Pass's Avatar
Originally posted by PMA
For completely dc coupled, result is the same.
What was your drive voltage?
Old 9th April 2008, 08:59 AM   #3856
PMA's Avatar
Well, I believe to come in a couple of hours with first webpage, summarizing our recent effort. It takes some time to get a result that makes sense and I hope you will tolerate that I prefer to create a web page rather than continue in single posts.
Old 9th April 2008, 12:32 PM   #3857
PMA's Avatar
It is slowly starting, and will be continued ...
http://web.telecom.cz/macura/diyaudio/jfetdist.htm
Old 9th April 2008, 01:24 PM   #3858
PMA's Avatar
continuing with complementary differential pairs ...
Old 9th April 2008, 01:39 PM   #3859
PMA's Avatar
... and finally the INGENIOUS circuit ...
Congratulations, John.
Old 9th April 2008, 02:29 PM   #3860
PMA's Avatar
for single-ended input ..
Closed Thread
Page generated in 0.23622 seconds (63.12% PHP - 36.88% MySQL) with 11 queries
