John Curl's Blowtorch preamplifier - Page 21 - diyAudio
Closed Thread
Old 22nd January 2006, 10:17 PM   #201
expert in tautology
bear's Avatar
Unhappy Bob Crump was a good friend...
Great guy.
Passionate about his audio fer sure.
Bought one of my Symphony amps, my cables and interconnects, his reference for many years, exhibited at CES with my amp... he loaded it in the back of his Turbo VW (performance chipped) and drove it up to 'Vegas at least one year... just talkin' with Bob was quite a thing!
I remember when he told me he was going to go into the biz, and about the Blowtorch... ahhh well.
Been too busy to be online here very much over the last weeks...
I spotted the thread on the Blowtorch... :-(
Only to find that Bob has passed away.
I was having a pretty good day up until then.
Bummed my space, big time.
That's a big vacuum to fill up.
crap.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 22nd January 2006, 11:22 PM   #202
john curl's Avatar
Hi Bear, Isn't that your silver hook-up cable in the preamp? I love the stuff!
Old 22nd January 2006, 11:33 PM   #203
johnferrier's Avatar
Just wonder if John Curl will comment on where audio is going to be in the future. Futurists like Ray Kurzweil talk about how rapidly technologies are advancing. Are there going to be large breakthroughs in audio technology? Major advances in transducers around the corner? Thanks for any thoughts.
Old 22nd January 2006, 11:45 PM   #204
John,
I have been embroiled in this Lovoltech power JFET thing and haven't made time to read this thread. Currently, I'm up to page 10 and want to drop in a comment or two and a question before I forget, then I'll go back to reading. I'll ask your pardon if this has been covered between p10 and here.
--I have long been a proponent of using regulators for each channel and for each stage. This has earned me more than one strange look and quite a few unkind comments.
--I have, over time, simplified my regulators. I used to go with one really, really over-the-top regulator coming from the rail directly to the circuit. I now tend towards two, sometimes three regulators, each reducing the voltage a bit, rather than all at once. I'm not sure why it sounds better this way, but I like it.
--I have experimented with electrolytics, films, and sometimes no caps at all after the regulators. Since regulators tend to function as low-pass filters, I find that electrolytics back towards the transformer end of things are not too big a problem, although I don't care for them after final regulation and before the circuit. Film caps are best here.
Now for my question:
Have you found that not having a cap after the final regulation tends to cramp dynamics?
I've observed that it's possible to get really, really beautiful sound at low signal levels, but that a peak falls utterly flat, dynamically.
To the extent that it's possible to design a circuit that has essentially DC current draw (e.g. differential) that can lessen the problem, but it's not always feasible to do so.
Comments?
Grey
Old 22nd January 2006, 11:55 PM   #205
John,
Ah...in your post on the next page (#108), you make much the same point that I do about cascading (I have a mental image of water cascading down a mountainside, each step lower--you, quite correctly, say series) regulators.
But why does this sound better? I can hear it, but the reason has eluded me.
Grey
Old 23rd January 2006, 12:36 AM   #206
Banned
Send a message via Yahoo to Elso Kwak
Cool worse
Originally posted by GRollins
John,
Grey
In my experience it does sound worse!
Old 23rd January 2006, 12:55 AM   #207
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Hi Elso, glad you mentioned that. I didn't want to be the first with the bad news
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 23rd January 2006, 01:05 AM   #208
Can you make it sound worse? Of course. It depends on what you're using for a regulator circuit.
Grey
Old 23rd January 2006, 01:06 AM   #209
serengetiplains's Avatar
Grey, I would guess the regulators are each successively cleaning the rail of mains garbage?
Old 23rd January 2006, 01:31 AM   #210
Possible, but I lean more towards the idea that a single big regulator, meaning one hefty enough to drop a reasonable amount of voltage and current at the same time, is going to require a larger device, be it FET, bipolar, or MOSFET.
All other things being equal, a large device is generally noisier. (Yes, I'm going to try the Lovoltechs in regulators, but bear in mind that there are no P devices for the negative rails.) That device-generated noise will require filtering, which will mean caps, inductors, or another stage of regulators. So you end up with this infinite regression of regulators to filter the residual junk from the upstream regulators.
In other words, the regulators themselves become the problem.
Smaller regulators, needing to pass the current (in the case of series regulators), but not necessarily a lot of voltage can use lower noise, higher quality pass devices.
However, this is only a hypothesis. I was hoping that John might comment on this and my earlier question about dynamics.
Grey
Closed Thread
Copyright ©1999-2017 diyAudio
