#20011 | |
What does typical audio equipment mean ?? That could mean anything. If you mean a cheap DVD or CD player then of course you will only find 4558's in them ![]() The underlying debate here from your side of the camp is that compared to a discrete design, modern high performance op-amps add artifacts to the sound that can't be measured. regards trev |
#20012 | |
John, As you know, PIM and FM distortion are one in the same. One is just the integral of the other. The PIM thing has been beaten to death. You've never measured PIM, so how do you know that PIM is less in a discrete design? Here is an important point. According to theory and measurement, PIM cannot exist in ordinary designs in the absence of amplitude intermodulation distortion. The key, then is to use devices that measure very low distortion in the conventional measurements. That is going to rule out/ weed out 741-like designs that are buried in chips or equipment. It is almost inconceivable that an op amp that measures below 0.001% THD-20, CCIF IM and SMPTE IM can have any significant amount of PIM. There is a caveat. I don't think that one can rule out the existence of PIM in designs that exhibit higher levels of conventional distortions, whether those distortions are benign or not. An example there might be vacuum tube amplifiers, where the higher, but perhaps benign conventional distortions would tend to mask an inference of low PIM. There I think the only option is to actually measure it. I have never measured PIM in a tube amplifier, but it might be interesting to do. One might be able to make an argument that tube amplifiers may have significant PIM as a result of the quasi-saturation that high-amplitude low-frequency signals cause in the output transformer. Cheers, Bob |
#20013 |
#20014 |
Hi John, all,
I split out the posts relating to test equipment to this thread. As I am interested in this and I feel that many other people who do have this issue (older test equipment), I'm asking for any help or suggestions in that new thread. I didn't intend to have that discussion in this thread John, a new thread was my intention all along. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#20015 |
Hi John,
This current thread is impossibly long now. Doing any maintenance work is difficult as a result. I am going to lock this thread and begin a new one for you, but not until I return after an appointment I have to keep. Can you do me a favor then? Let me know where you would like this new thread to start. I'll split at that point, but keep this within 20 posts of this point please. I feel that this also presents an excellent opportunity to get back on track to talk about the Blowtorch preamp you designed. -Chris
| Page generated in 0.22883 seconds (62.02% PHP - 37.98% MySQL) with 11 queries |
