#19911 | |
John |
#19912 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#19913 |
Hi frequency response apparently has little to do with live vs recorded evaluation.
#19914 |
This thread was pretty darn good, up to page 100. After that, ?
#19915 | |
2012, our time is running out. |
#19916 |
#19917 | |
PS. I don't think you guys are having enough fun on this thread and it's a problem
#19918 |
John, I hope your new PIM test will explain why you and Dave Wilson chose the 741 third out of a long list of op-amps for his crossover.
#19919 | |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#19920 |
No, we just found that many IC's sounded worse for whatever reason. We, at least, expressed our results openly and honestly.
For the record, we evaluated the difference between IC op amps in a specific place, and it had NOTHING to do with Crown Equalizer that ultimately had to be updated. It was an OK test, and the results just showed that there is more to bad IC's than just slew rate. Ultimately, we made special modified IC's, composed of a diff fet input stage coupled into the offset adjust pins of a Raytheon 5534 IC, bypassing the input stage, to replace what Crown originally used. It worked pretty well, but was somewhat noisy. Linear input stage? |
| Page generated in 0.23400 seconds (62.55% PHP - 37.45% MySQL) with 11 queries |
