John Curl's Blowtorch preamplifier
Closed Thread
Old 14th June 2009, 08:05 PM   #19551
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
It strikes me that many people do not appreciate that people such as John, Joe Pass and many others have absolutely no need to post here. It also strikes me that there are some people who make a point of being rather objectionable to virtually anything an expert has to say. Others raise petty quibbles and some are just downright objectionable!
The first group - those with deep experience and knowledge which they give freely as far as they can (usually relying on the audio industry as the field in which they make their living) - are the givers of this world.
Those who set out simply to attempt to knock down the hard earned knowledge which is given - whilst usually having only a little knowledge garnished with half baked ideas - are not even the takers of this world...they are just knockers-down - with little to contribute.
Others who benefit from the site may well risk loosing the 'givers' because of the social irresponsibility of a very small section of members.
Old 14th June 2009, 08:14 PM   #19552
1audio is offline 1audio  United States
Originally posted by scott wurcer
I would love to see if this circuit is more suitable for discrete applications. I have to be careful and not make any lawyers unhappy so in this case I have to stick with simply pointing out what's there already (and in the public domain).
For those of us who have only a tenuous connection to IC design (when I was last close the masks were cut from Rubylith by hand, its changed a lot since then) how good is the transistor matching? I know there are trimming techniques (lasers and fuses) but I understand you have ways of holding devices to pretty close tolerances by design. That would make some tricks possible that are hard for discrete devices. At the same time with discrete parts its possible to get better isolation (thermal and electrical) than possible on a substrate. A little insight into those differences may help us on the outside see whats needed to get those ideas working in discrete parts.
Demian Martin
Product Design Services
Old 14th June 2009, 08:19 PM   #19553
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
You forgot about one more group, that tries to position itself above everybody, judging judges, contributing absolutely no technical ideas in any discussion.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 14th June 2009, 08:21 PM   #19554
syn08 is offline syn08  Canada
Yeah, right
Old 14th June 2009, 08:28 PM   #19555
KSTR is offline KSTR  Germany
KSTR's Avatar
... Joe Pass ...
Now that was a good one! I think that Mr.Nelson""Pass can live well with that mix-up.
Old 14th June 2009, 08:47 PM   #19556
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
Demian, far and away the biggest factor is the ability to ratio, exactly, emitter areas on IC's. The uniformity on modern IC's is shocking to those used to discrete design. Six sigma offsets of <100uV are common. Area ratioing is limited by photo lithography which is driven by sub-micron CMOS. Make big bipolars on the same equipment and you get super matching for free. Of course you don't make bipolar masks on the very best, we are approaching (maybe over) $1,000,000 for a 12" mask set.
The multi-tanh circuit needs an exact emitter area ratio, 4 is pretty close, so I figured 5 discretes pulled off of a strip is worth an experiment. I don't know if the second circuit is any better. I have another that I am pretty sure does not use area ratioing and still achieves a flat gm region (no PIM ), but this is unfiled IP that I can not share.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 14th June 2009, 09:05 PM   #19557
brianco's Avatar
That would include me of course!
Now I am really embarrased! Apologies Nelson.
Old 14th June 2009, 10:34 PM   #19558
Bob Cordell is offline Bob Cordell  United States
Originally posted by SY
I've removed a bunch of OT posts that dealt with personalities.
Thanks, SY.
You and the other moderators continue to do an excellent job on this thread in particular. We all need a kind reminder when we play a little too rough.
Bob
Old 14th June 2009, 11:33 PM   #19559
jam is offline jam  United States
jam's Avatar
SY,
.........I find it amusing that back in the day,squabbles usually occured among us regular members but today the so called experts/profesionals are more involved in free for all's.................go figure.
Old 15th June 2009, 12:29 AM   #19560
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
It will amuse you to know that my father's name is Joe Pass,
however he is in the aircraft industry.
Closed Thread
John Curl's Blowtorch preamplifierHide this!Advertise here!
