John Curl's Blowtorch preamplifier - Page 1907 - diyAudio
Closed Thread
Old 28th May 2009, 04:08 PM   #19061
john curl's Avatar
Some connectors look fascinating, but they seem to put more into the 'bells and whistles' than the solidness and purity of the contact. I'm for a good solid contact with an RCA connector.
"Condemnation without Examination is Prejudice"
Old 28th May 2009, 04:09 PM   #19062
h_a is offline h_a  Europe
h_a's Avatar
thanks for the pic, however if you look closely, you will see these are just the stock female RCAs mounted into their standard XLR-housing. Maybe they're better fastened though.
Have fun, Hannes
High Octane phono preamp Wiki
Old 28th May 2009, 04:21 PM   #19063
scott wurcer's Avatar
I would think it is important where the money is spent on an expensive connector. I figure the mfg is getting the most return on making mission critical connections that are reliable under extreme abuse and where the customer has a high cost of failure. I don't see a $200 connector using that cost to get better "sound". As with many things there is not a direct connection between cost and all interesting properties.
I just saw on the web all my Cramolin outdated years ago.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 28th May 2009, 04:21 PM   #19064
jan.didden's Avatar
Have fun, Hannes
Indeed! They also sell the empty 'buckets' for you to mount your own RCAs if you want that.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 28th May 2009, 04:48 PM   #19065
R.I.P.
Before we started making commercial interconnect cables, we listen tested every RCA plug we could find. In an extremely high resolution system, the Eichmamm solid silver Bullet plugs came out on top, followed by the Eichmann copper Bullet plugs.
We had hoped the new WBT "Next Gen" plugs would win out as they are even more aligned to out theories, but they were quite a way down the list - until we tried them without their metal outer locking cover. Then they became almost as good as the silver Bullets, but impractical to use that way.
But the Eichmann's are poorly constructed and easily melt during assembly if you are not careful.
The best audio connector IMO/IME is the LEMO range - a la ML/JC of the first productions. We now use the plastic bodied version of the LEMO called the Redel as our balanced connector of choice on our top balanced equipment, with XLR, and RCA for paralleled unbalanced connections.
Regards, Allen
www.vacuumstate.com
Old 28th May 2009, 04:57 PM   #19066
john curl's Avatar
Thanks Allen, for some 'real' input. Eichmann connectors score very high with my associates, too. WBT is lower on the list. So much for show, and bulk. I have stuck with Vampire, because I have used them for decades, and they work OK. Send me an e-mail with your personal e-mail address, and I can send you a PDF of an article that will knock your socks off, AND prove a few things, with measurements, denied here. I think it was originally sent to me by someone here, I will have to check.
Old 28th May 2009, 05:26 PM   #19067
Refereed proof of some claims made here would be great. It would clear the air, and I for one would welcome it.
Old 28th May 2009, 05:30 PM   #19068
john curl's Avatar
I don't think so.
Old 28th May 2009, 05:32 PM   #19069
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
As connectors came up: does somebody have a suggestion for well made RCA/Chinch connectors?
I would prefer military silver BNC, but I can't replace them on all devices I see!
Also, as soon as the law demands grounding through outlet, I would go with balanced interconnects everywhere in audio path. XLR is fine, but some military sockets would be better, as well.
The Devil is not so terrible as his math model is!
Old 28th May 2009, 05:36 PM   #19070
Thanks JC
Closed Thread
Copyright 1999-2017 diyAudio
