John Curl's Blowtorch preamplifier
Closed Thread
Old 17th May 2009, 04:10 PM   #18561
On Hiatus
SY's Avatar
It's Teflon. You can make a cap out of it, but it will be loose, microphonic, and unrepeatable.
Scott's humor.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 17th May 2009, 04:44 PM   #18562
audio845 is offline audio845  United States
I'm just a amateur designer but I did spend 10 years as a professional musician so I have a pretty good set of ears. I've been listening to different caps for the past 15 or so years and I CAN hear a difference no matter what the naysayers are crying. Having said that I believe that the Teflon caps (both the Vcaps and the TFTs) sound the best. I like the RTs in small values but in larger values I think the PPFXs are the best sounding next to Teflon (the RTX sound slow and rolled off in comparison). I have no idea why this is, but I can certainly hear the difference. I build tube gear which may also make a difference in how the caps sound with the higher voltages involved.
I have heard multiple possible explanations from DA to damping to self resonance. Perhaps it is a combination of all of these or maybe something that hasn't been measured yet - but the difference is easily audible in tube circuits with their inherent simplicity.
Charlie
I'll guess I'll have to try the plumbers tape. ''
Old 17th May 2009, 04:59 PM   #18563
h_a is offline h_a  Europe
h_a's Avatar
Does that mean I can't make my own caps with plumber's tape?
Come on! The tube guys have their huge transformers ontop of the chassis, so why not huge rolls of plumber's tape on solid state gear?
Capacitance must be a real joke at this density.
Have fun, Hannes
High Octane phono preamp Wiki
Old 17th May 2009, 05:18 PM   #18564
john curl is offline john curl  United States
john curl's Avatar
Audio845, that is exactly the kind of input that I appreciate. I wish that I got more of it on this thread, because I can learn from it, if only your studied opinion. When I get a 1/2 dozen opinions just like this from people who don't even know each other, then I know we are on the right track.
For example, when I spoke to JAM, a sometime contributor to this thread, he knew the sound quality of the REL RT's instantly and gave me his independent input. I have never met JAM personally, or listened with him, but we share an amazing 'coincidence' in listening opinions on caps.
However, it may depend on the cap value and application as to which cap is best. For example, for loudspeakers, all bets are off with me, because I have so little experience with making passive speaker crossovers.
"Condemnation without Examination is Prejudice"
Old 17th May 2009, 05:50 PM   #18565
nicoch58 is offline nicoch58  Europe
Can I ask what difference signature have rt-teflon$$ on 100nf riaa (Erno phono)
Old 17th May 2009, 06:24 PM   #18566
john curl's Avatar
I can't access what the cap difference is with other circuits, but I used to have a T mod for a Vendetta SCP-2 that exchanges Teflon for RT polystyrene. I found the Teflons more 'dynamic' in my own phono stage for EQ.
Old 17th May 2009, 07:04 PM   #18567
Hi nicoch46,
You'll probably hate this kind of answer but to me the teflons sound more "natural". What does that mean? They are more dynamic but also have what I'll call a more correct harmonic signature. An oboe sounds more like an oboe and a clarinet sounds more like a clarinet. I was (am) a pianist and for me the transients both at the start and the stop of a note are very important and the teflons get this better as well.
Now having said all this the difference is small and unless you are shooting for the absolute best you can do, the PPFX or RT would certainly be fine. Either one is reasonably priced.
Charlie
Old 17th May 2009, 07:28 PM   #18568
john curl's Avatar
I happen to agree, and I don't even know you, Audio845.
I wish it weren't true.
Old 17th May 2009, 08:05 PM   #18569
nice answer
thanks John /Charlie
is great pity that many people do not realize that there are substantial differences by changing just one strategic component ...
in my small experience change the Rload of cartridge from dale to tantalum (that is the first component of the chain) made the sound more sweet with a lot reverb-space info...just some
Old 17th May 2009, 08:51 PM   #18570
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
It greatly depend on where that component is placed, I would not call it a strategic place, but rather a bottleneck.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Closed Thread
John Curl's Blowtorch preamplifierHide this!Advertise here!
