John Curl's Blowtorch preamplifier
Closed Thread
Old 18th February 2009, 02:03 AM   #14561
On Hiatus
SY's Avatar
Just to be clear, by "temperature sensitivity," I'm referring to reliability rather than tempco.
syn, what's so special about the PPS caps? It's an OK dielectric and certainly thermally stable, but what does it bring to the table that I wouldn't get with an ordinary polypropylene cap?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 18th February 2009, 02:03 AM   #14562
zapnspark is offline zapnspark  United States
zapnspark's Avatar
I suppose I'm wasting my time suggesting that some folks here try reading these C. Bateman articles on capacitors.
Oh well. One more try.
http://tinyurl.com/bwsh9b
capsound1.pdf -- capsound6.pdf
These are free downloads.
ZAP
Old 18th February 2009, 02:06 AM   #14563
anatech is offline anatech  Canada
anatech's Avatar
Hi syn08,
Very good, most likely better than silver micas.
Thank you.
Yes, I agree these days. 10 years or so ago I probably would have disagreed with you. So is the power of the audio press. I'm glad I started testing some before I opened up my mouth!
Try this one, if it won't make you happy then nothing else on this planet will.
Those are the ones I have been using lately. I don't have an opinion on whether they are better than the others I use, but I can't see anything at all wrong with them. They even look nice, each one looking much like the next instead of some that are "bloby" looking.
Hi Andy,
Here's what Cyril Bateman has to say about NP0:
That is one source that made me reconsider my stance on these capacitors. I think quality may come into play here, much as it does with Mica capacitors. The one thing I don't like about some Ceramics is that they may short around the outside edge. I think that is due to poor manufacturing but I may be wrong there. Man, can they ever burn!
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 18th February 2009, 02:07 AM   #14564
andy_c is offline andy_c  United States
Banned
Originally posted by zapnspark
I suppose I'm wasting my time suggesting some folks here try reading these C. Bateman articles on capacitors.
Yes, those are excellent. Nothing like real data! My quote of Cyril Bateman above was from one of the files on his CD I purchased. It's not in the freebie downloads.
Old 18th February 2009, 02:12 AM   #14565
Banned
Hi Chris,
Not sure if you've seen this, but here is the Bob Pease "soakage" (DA) article from back in the '80s that made me think of this. I was working with S/H circuits for military apps at the time, and it definitely influenced my choice of hold capacitor.
Old 18th February 2009, 02:16 AM   #14566
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
John Curl's Blowtorch preamplifier Send a message via AIM to Peter Daniel
I've heard stories about very good silver mica caps from Germany, here's one: http://www.diyaudio.com/forums/showt...2788#post22788
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 18th February 2009, 02:16 AM   #14567
anatech's Avatar
Hi SY,
Yes. Sorry, I was unclear also.
Most Polystyrene capacitors die when being soldered in or reworked. Do not resolder these without good reason. It helps a lot to use some type of metal clip between the body of the part and the lead you are soldering. Get it soldered and remove the heat as efficiently as you can. I still use some component lead heat sinks I bought from Radio Shack way back in the 70's. Some early transistors were equally touchy about heat.
I didn't notice anything so far. They are just another possibility when the other types are out of stock for me.
I look for capacitors that don't do bad things more than the "drops of pure heaven" these days. Many good capacitors don't sound much different, and they don't appear any different on my THD meter or spectrum analyzer. Some capacitor changes do make a measurable difference on even a THD meter (HP 339A). Even my old Leader THD meter could measure a small but repeatable difference between nasty ceramics (or tantalum) and a better replacement. I figure that I the difference is so small that I have to really work to hear the difference, so will the customer and I'm not about to expose that person to more cost than required.
-Chris
Old 18th February 2009, 02:26 AM   #14568
anatech's Avatar
Hi Andy,
Yes, that was also a good article. I found it later and was relieved to find it re-enforced the views I was coming to accept. I came across that one while building a DVM circuit.
Thank goodness for the test and measurement field! It seems they demanded the parts we require for audio use. That's probably the only reason those parts existed in the first place. I guess I was lucky to have interests in both instrumentation and audio. Otherwise, much of what I learned would not have been available to me.
What more can I say? The T&M industry will always get it right. It's too important to make errors there and that industry has enough cash as a result to do these studies. Far more rigorous standards for the better equipment than audio. Often the required bandwidth is far greater as well.
-Chris
Old 18th February 2009, 02:50 AM   #14569
Banned
I wonder what Robert Harley's opinion of NP0 ceramics is?
Could any high-end designer afford to put such capacitors in his designs without risking the scorn of a bunch of self-important blowhard audio reviewers?
Old 18th February 2009, 03:08 AM   #14570
syn08 is offline syn08  Canada
As you said, better temperature stability (e.g. dissipation factor is constant up to 100 degrees centigrades). But one to another an excellent cap that makes teflon look like an unjustified expensive option, together with $1000 power cables and unbleached cotton insulated silver wire. Give me one shred of proof (beyond "sounds good") that teflon is bringing anything special to audio.
Closed Thread
John Curl's Blowtorch preamplifierHide this!Advertise here!
