#13851 | |
As a child i remember a valve radio,a three position volume switch,and another for loud or quiet Jan You posted a bit about the QTC pill doodads yesterday. I used a pair of these as pressure variable resistors in series with the inputs to a power amp,Worked well I thought,for their crudity. Their hysteresis would drive a control freak Mad though. regards Max ps Perhaps using them under constant pressure as varied resistors,but then it"s back to switches. pps apologies for refering to Qtc again,Thought everyone would know about them. |
#13852 | |
Are you refering to the post where he said it was his favorite volume control? |
#13853 | |
Indeed, looks good, though I'm not sure if I can trust a company that also sells BS. Regards, Edmond.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#13854 | |
Pain is never permanent |
#13855 |
Sony TA-E88 attenuator/balance
The border between the Real and the unreal is not fixed, but just marks the last place where rival gangs of shamans fought each other to a standstill. Robert Anton Wilson |
#13856 |
And the TA-E88 output level switch.
Regards James
#13857 | |
I'm referring to the post were Peter Daniel said: Yes, Placette is very well regarded and I've been using it for a while myself. However, after initial excitement, I was starting noticing defficiencies, mainly the coloration. And: But in the end, TVC is not perfect either. I have a chance listening without any attenuator now as the amp has just the right gain for normal levels and it's very revealing experience. |
#13858 |
It is always surprising to me the subjective correlation of resistor sonic quality from people who have never even met each other. The general consensus is: Holco (old) soft., Holco (new) problematic, Resista (balanced, but imperfect), Vishay bulk metal standard, overly etched, but better, if ordered without case. Etc.
I have 100's of different resistors that look good and measure OK, BUT don't sound good. I do wish that I could find the reason, or at least be able to sell off my excess to the hear-no-difference group, so that they can use them with impunity. Scott, Cordell, let's make a deal!
#13859 | |
#13860 |
i think we should consider the volume control stepsize.
Just because you can't hear it doesn't mean no one can. |
| Page generated in 0.25983 seconds (64.45% PHP - 35.55% MySQL) with 11 queries |
