John Curl's Blowtorch preamplifier
Closed Thread
Old 3rd May 2006, 12:37 PM   #1101
Geophysicist is offline Geophysicist  United States
Default John...
EVERYBODY who hears it, likes it! I have owned a lot of preamps over the years (with one exception, all tube types). The Blowtorch is the best of the lot, and not by a small margin either. Needless to say, it mates well with my JC1s
Old 3rd May 2006, 06:27 PM   #1102
Badge is offline Badge  United States
I have heard the Blowtorch in several systems including mine. Bob Crump visited and was kind enough to bring his personal preamp. I am sure John has made it clear that this product is the combined effort of three talented people. John does the design and board assembly. Carl Thompson did the design of the boards. He is a retired designer of state of the art video production equipment. Layout is so critical with that type equipment. And, the late Bob Crump was responsible for the voicing and final assembly of the preamp. Bob was one of those unique people who carefully evaluated every component for sonic character. Every switch, wire, connector, resistor, cap, etc. is specifically selected for their application. I mention all this to point out that the circuit design is just a part of this amazing product.
This thing throws the most holographic image I have experienced. The noise floor is nil and every performer is so clearly defined in that space. Let me give you a example of it's ability. I was sitting in the sweet spot while Bob sat at least 45 degrees off axis close to the left channel speaker. He asked me to switch places with him and check out the image. I did and to my total amazement, the image was stayed steady and everything was still in the same place in the soundscape. Simply amazing IMO. Now if I could just afford one
The freaks stick together, they are a tight old crew
Old 3rd May 2006, 06:45 PM   #1103
Upupa Epops is offline Upupa Epops  Czech Republic
Default ...still in th same place...
Space imaging is mainly made by attributes of speakers....
Old 3rd May 2006, 06:48 PM   #1104
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Default Re: Blowtorch in Europe
Originally posted by Geophysicist
Well, that MAY change. I'd estimate roughly 50:50 odds that there will be one in London this year - mine.
I might take you up on that, and I'll show you some good pubs in return.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 3rd May 2006, 06:50 PM   #1105
Panelhead is offline Panelhead
Default Imaging
If the imaging works off axis as well as it does in the sweet spot, the speakers also are very special. My speakers are not so forgiving.
This artifact of playback indicates that the phase is fairly flat across the midband. Plus no frequency related delays.
This is an area where the lack of feedback is beneficial. Feeback usually screws with the phase response. This may be why some prefer no feedback for small accoutic music and feedback for large orchestra. The multi-miked recordings really are all over the place when it comes to preserving an event.
George
Old 3rd May 2006, 07:06 PM   #1106
You have in it little bit mess, George... Good and fast amp have only several degrees of shift at the edge of accoustic band and on the middle is it only tenths of degree...
Old 3rd May 2006, 07:31 PM   #1107
PMA is offline PMA  Europe
PMA's Avatar
Default Re: Imaging
This is a total nonsense, demonstrating how the "marketing science" washes brains of the poor DIYers.
Phase reponse is unambiguously related to amplitude response. Wide amplitude response means minimal phase shift in the midband. For the system with bandwidth 2Hz - 300kHz (which is quite normal) there will be no interesting phase shift in audio band.
Old 3rd May 2006, 07:53 PM   #1108
PMA's Avatar
The attached picture shows amplitude and phase responses of the power amp that I use. It is a feedback design, OLG = 80 dB, OLG frequency cutoff corner (-3dB) > 20kHz, closed loop gain = 32dB. I would be grateful if someone could show me significant phaseshifts in the audioband.
Old 3rd May 2006, 08:01 PM   #1109
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Default Re: Imaging
George,
which ones are you using ?
Old 3rd May 2006, 08:36 PM   #1110
Default Badge...
I would suspect that what you experienced was a combination of the dispersion characteristics of the speaker combined with the exceedingly low noise floor of the preamp (and amp?). The low noise certainly contributes to the illusion of image specificity. For what it's worth, I have noticed the same phenomenon with the Blowtorch, Parasound JC1s, and Sound Lab A-1s.
Closed Thread
John Curl's Blowtorch preamplifierHide this!Advertise here!
