Closed Thread
Old 27th April 2006, 01:06 PM   #1021
EUVL is offline EUVL  Europe
Enough excursion to my layout.
Let's get back to circuits.
I want to refer to Richard's schematics.
Would it not be better to use a voltage reference or LED's (to replace e.g. R5) in combination with a CCS diode like J511 (to replace R1) to bias the MOSFETs ?
I expect at least better PSRR ??
Patrick
Old 27th April 2006, 01:22 PM   #1022
What do you can extend, Patrick ? Do you know correlation between " on paper's parametres " and sound quality ?
Old 27th April 2006, 01:38 PM   #1023
bogdan_borko's Avatar
can someone give me the lik to the schematic of blowtorch preamp???
Old 27th April 2006, 01:46 PM   #1024
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Patrick,
sticking the elektrolytics through the heatsink is funny.
I recollect that EB seems to favor fast regulation for his EB-116 lineamp too instead of CCS's. Is it me, or does it seem that CCS diodes are not in much use ?
Bogdan is even funnier, lets give him a lik.
Looks like Sponge Bob has killed another thread.
Old 27th April 2006, 01:51 PM   #1025
anatech is offline anatech  Canada
anatech's Avatar
Hi Bogdan,
John Curl, who designed the preamp, is selling it commercially. He has stated he has no intentions of releasing the schematic. I'm sure there are unit to unit variations to compensate for component variables. I fully support John's decision to not release the diagrams for those reasons.
If you read the entire thread, there are many clues. This is more of a gift as you can apply these lessions to your own low level designs.
Read and learn.
-Chris
Old 27th April 2006, 03:18 PM   #1026
uli is offline uli  Austria
Releasing the Original would make this thread boring and senseless
Uli
BTW: did anybody ever try the LSK389 type C as the 2SK389 fades away?
'Jazz is not dead, it just smells funny' F.Zappa
Old 27th April 2006, 04:29 PM   #1027
PMA is offline PMA  Europe
PMA's Avatar
How about this one?
Old 27th April 2006, 04:55 PM   #1028
Originally posted by uli
ever try the LSK389
Uli,
i'm sorry, i seem to be dyslectic. Can you show the link to the LSJ109 ?
I always have that problem with P-channel fets.
Old 27th April 2006, 06:12 PM   #1029
Be calm, Jacco, and use some " normal " one... By line level preamp, with 3-5 gain isn't noise so critical - is free, if SNR is " only " 120 dB and not 126-130 dB.....
Old 27th April 2006, 07:54 PM   #1030
plep is offline plep  Belgium
Default back to the psu ...
I’m trying to put the ideas gathered here to work (serie reg + CCS + shut reg).
I still use the basic Curl follower running under switchercad. I think this circuit is both less sensitive to the psu and “harder” to the psu than the symmetric folded cascode we are talking about here. Sorry If I’m lagging ideas by Richard and allied…
How can I improve the line regulation provided by the simple shunt reg ? I imagine that higher gm transistors would help (which ones?). At about 100ma the gm of the irf640 and irf9540 are just a bit above 1S. Regulation is quite similar to the one provided by a .85ohm internal resistance voltage source.
I can obtain a slightly more linear regulation in high frequency with a small (about 470nf) in // with the reg. It also helps to eliminate the overshot one can see with square waves (I think that Richard published them a while back). Funny, John says “no cap” and he must have good reasons.
A “massive” approach to passive filtering, 3 cells composed by a 10ohm resistor and a 47000µf 1nH ESL and 3mohm ESR cap (I hope these values are realistic), provides a much higher attenuation in most of the audio frequencies and above, but this attenuation is changing with frequency and there is a severe bump at very high frequency (due to very low esr ?). I know that only the last cell is useful in term of regulation.
The active reg shines in terms of line rejection. I probably obtain one more time meaningless results because real live noise masks the simulated behaviour that lies at impossibly low levels. Anyhow, I think that the curves are interesting. For instance, you have a less acute peak in HF using 3 different caps in the passive way and you can see the interest of multiple cells.
Any help and comment gratefully welcomed.
Philippe (who as difficulties to explain himself in English and whose mail is broken :-/).
Closed Thread
Page generated in 0.24171 seconds (61.88% PHP - 38.12% MySQL) with 11 queries
