Old 7th January 2006, 08:17 AM   #1
jlm is offline jlm  France
Default LM317 and LM337 Regulators in parallel
Hello,
I search a schematic to put in parallel 2 LM317 and 2 LM337
and another schematic with 3 LM317 and 3 LM337 in parallel .
Thank you for your answers
Best regards.
jlm
Old 7th January 2006, 10:17 AM   #2
jackinnj's Avatar
for cost reasons, current carrying capacity is often boosted by using a pass transistor ('2905, '3055) around the regulator instead of paralleling devices. you can parallel the devices, however -- it's just a few centimes more expensive.
If you decide to parallel these regulators, place a small resistor (0.1 or 0.22 ohm) in series with each output. This will make them happier in sharing the current.
National Semi's product folder on the LM317 shows how to boost current capacity -- they use a super-matched pair of transistors (because it was a device they manufactured) -- you can use MJE2955, 3055.
Old 7th January 2006, 10:34 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
What are you going to use these regulators for? Maybe we can suggest something better/different?
/Per-Anders (my first name) or P-A as my friends call me
Old 7th January 2006, 04:03 PM   #4
Onra is offline Onra  Germany
for the positive supply you can replace 3 LM317 by one LM338T or K.
The T-version comes in a TO220-case and K means TO3.
The negative branch will become more difficult, because there are afaik no regulators of more than 3 A.
In the LM317 and LM337 datasheet (NatSemi) are applications with paralleled devices to increase their current capability.
Onra
Old 7th January 2006, 04:20 PM   #5
jackinnj's Avatar
Linear Technologies LT1185 negative regulator will do 3 amps.
Old 7th January 2006, 04:50 PM   #6
lineup is offline lineup  Sweden
lineup's Avatar
this is the way I would prefer, too
for the positive LM317 you use a PNP TO3 transistor
for the negative LM337 you use a NPN TO3 transistor
Here is link to such a project with description:
LM317T Voltage Regulator with Pass Transistor
lineup
Old 7th January 2006, 07:48 PM   #7
same post appears at "electronics and parts".
Is it possible to concentrate these posts to one?
Onra
Old 7th January 2006, 08:08 PM   #8
Danko is offline Danko  Hungary
It's in the "powersupply designing" section.
Onra, ask one of the moderators, to merge theese two topics.
For example Sy, or pinkmouse :-)
Best regards, Danko
Best regards, Danko
Another look at the LM317 and LM337 regulators jbau Power Supplies 315 9th November 2011 09:50 PM
LM317 and LM337 Regulators in parallel jlm Power Supplies 2 7th January 2006 08:50 AM
Page generated in 0.11816 seconds (70.16% PHP - 29.84% MySQL) with 10 queries
