diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   problems with mofset car ampilifier (http://www.diyaudio.com/forums/solid-state/71152-mofset-car-ampilifier.html)
hicksy_5 6th January 2006 08:25 PM
hi im having some problems with a 12v car amplifier i dont think any of that mofsets or transorferms are gone becuse it still works some times thats the problem it works some times and other dosent have any power i have had i look in side but when i did everythink worked there arnt to many wires to go loose and i have allredy tried that
thanks in advanced
ps. i am after a power supply to power it but carnt find any with the power that it needs i have come acrosss a forum saying you can make one with two pc power supply but they are useing 400w ones i only have 200w's
Leolabs 7th January 2006 01:14 AM
Try to resolder all the solder joints.
sagarverma 7th January 2006 06:46 AM
dry solder joints.
resolder the ckt.
hicksy_5 7th January 2006 11:23 PM
thanks for the help do you think it might be the thermostat the heat cut off or somthing do you know how to disable it or fix it im not sure what is wrong but it could be sitting there and with out any movement or anything it just cut out
DoomPixie 13th January 2006 02:52 AM
as has been said already, it's probably dry joint's somewhere. the amp heats up and the conection is lost. have a look at all the solder joints with a magnifying glass and see if you can see any that look cracked atall or look dull, if you find any liek that then resolder them. if you do this and it is still not working then report back and we will try and help track down the problem. I'm not sure this thread is int he right place though?
Owen
Resources saved on this page: MySQL 18.75%
