Old 15th January 2006, 01:01 PM   #11
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by Bensen
lineup,
I've been using the midpoint between the two diff pairs, because I don't have a CCS to feed the diff pair.
When you will use a CCS, you can control the current throught the diff pairs with the DC-servo.
See the attached picture to have an idea. I've found this somewere on this forum.
Greetz
Ben
Now, I see you are using a DC-servo feedback circuit, using an OP-amp.
Tthis was not in your circuit before.
I think I saw amplifierguru show somewhere,
how to use correction in between emittors in a symmetrical differential input.
lineup
Old 15th January 2006, 01:37 PM   #12
lineup's Avatar
Here it is with his diagram:
http://www.diyaudio.com/forums/showt...815#post799815
It is from the topic: To use DC servo or not?
I belong to those who do not use DC-servo.
I know it is theoretically a more safe method, especially without input capacitor.
I always use a DC-blocking cap at input.
Yes, in some of my amplifiers even Output DC-blocking Capacitor
which makes DC-offset very much less of a problem!
Even those that does not use output cap, in fact in 49 cases of 50,
use an output cap to at least the tweeter in loudspeaker.
First and second order x-over uses 1 capacitor.
Higher order can use several caps in series.
3-way system use capacitor(s) to midrange woofer and tweeter.
Using active filters makes use of same number of coupling capacitors.
Big difference here is using resistors instead of inductors.
What about an inductor in signal rail. Well most of us use it!
Have a look at a typical LSP crossover high-pass filter.
.... and they think their system is truly DC-coupled
lineup
Old 15th January 2006, 01:37 PM   #13
Bensen is offline Bensen  Belgium
Bensen's Avatar
Lineup,
You understood me wrong. In the schematic from post #6, "V7" is supposed to be a DC-servo circuit. But I just didn't draw the hole servo systeem.
Yes, "P1" is there for to compensate the DC-offset.
Old 20th November 2008, 03:39 AM   #14
lineup's Avatar
okay
I misunderstand sometimes. Give me for
anyway, this compensation trick is something i still use
when working with bipolar input transistors
JFET input has almost zero Bias Current
lineup
cmoy dc offset correction magnade Solid State 0 5th August 2009 04:22 PM
Thermal Compensation Bias hawkfeather Solid State 4 23rd January 2006 09:57 PM
Alternative offset correction for Alephs. Netlist Pass Labs 4 28th September 2005 08:39 AM
dc offset correction pot mirlo Solid State 5 31st July 2002 11:22 PM
Offset compensation? Vg Multi-Way 2 6th June 2002 12:26 AM
Page generated in 0.90606 seconds (9.68% PHP - 90.32% MySQL) with 11 queries
