Old 5th January 2006, 08:07 AM   #11
ilimzn is offline ilimzn  Croatia
Originally posted by AndrewT
thanks gentlemen for another angle on Gm. It helps me get the difference between LFET and VFET into my mind.
Actually, perhaps the proper way of referring to these devices is LMOS and VMOS. Reason being, there is (or rather was) such a thing as a VFET - a power JFET. Most small signal JFETs are lateral, i.e. LFET.
Biasing the push pull LFET output stage with a BJT driver pair.
Should the bias temp compensator be attached to the driver heatsink? to keep the bias voltage to the gates substantially constant.
This is usually not necessary because the driver pairs are degenerated by their emitter resistor(s), so their effective tempco is lowered, unless we are talking big currents and small resistors.
most LFETs have an Id max = 7A. Only >=10A when driven in one shot short term peak. So you should never see Vgs=10Vpk when on any music signal.
Actually, you might be surprised. First of all you need to check what is a 'short term peak'. For instance, on many parts this is defined so that substantially higher than IDmax(DC) can happen on a normal audio signal half-wave (keep in mind that to a large degree the complementary devices share the load). This is important because even at midlevel loudness, amps DO clip. By your reasoning, one does not need gate protection zeners
There are a couple of other examples where you might get unexpectedly high Vgs, such as clipping (even without a load) with stages that have higher rails for the driver stage, oscilation (god forbid), shorts, very reactive loads. As ritchie00boy said, the example was illustrative, not necesairly real, but it is good practise not to let these thing to chance.
After allowing for temperature derating your current limit is even lower and if it is a short circuit current then the SOAR limit brings permissible Id much lower still. [/B]
True, but consider what happens when you short circuit the output. The NFB fails (since it's input is shorted) and any signal slams the gates all the way up or down. Depending on how you drive your outputs, you may get a full rail voltage as Vgs. MOSFETS in general are FAR less tolerant of Vgs limits being broken, than od Id limits being broken - the likelyhood of survival is a lot higher in the second case.
Old 5th January 2006, 09:02 AM   #12
Hi Illimzn,
thanks again.
I agree that zener protection to prevent excessive Vgs is necessary.
Weird voltages can accidentally appear on the gates. Clipping is an accident that should not happen during music reproduction but probably inevitable and should be protected against.
I have changed the Zeners on my Sugdens from 12V to 7V5 to help control excessive output current. Additional zeners inserted directly from gate to source pins. Retained the standard 12V at the driver emitters.
Vgs = rail voltage is why the VAS transistor must also be protected if the output protection triggers. (assuming VAS > driver> Vmos).
regards Andrew T.
Old 5th January 2006, 09:09 AM   #13
Hi Ritchieboy,
yes, David was just comparing
the big differences in transconductance between lateral and vertical devices
But he took the lower current devices (Lmos) outside their operating envelope while keeping the higher current (Vmos) inside the envelope. That makes the comparison invalid. If he were to multiply the Lmos device quantities up to closer match the current ability of the Vmos devices then the high current drive voltages of the Lmos would be much closer to the Vmos.
Which brings us back to the original Question is it possible to replace Vmos with Lmos, probably not worth making the change due to;-
1. the need to check and probably change the design to suit Lmos
2. the considerable cost of multiple driver replacements for what level of performance improvement, if any.
regards Andrew T.
Lateral MOSFET thermal vs others jackinnj Solid State 6 21st March 2009 01:20 PM
emulating a lateral mosfet hitsware Solid State 3 11th January 2009 02:53 PM
Lateral MOSFET torture... megajocke Solid State 11 11th November 2007 07:08 AM
Lateral Structure Mosfet UltimateX86 Solid State 9 16th July 2004 09:50 AM
Looking for lateral mosfet spice models ojg Solid State 3 15th November 2003 11:56 PM
Page generated in 0.07804 seconds (83.49% PHP - 16.51% MySQL) with 10 queries
