Old 2nd January 2006, 04:52 PM   #1
ppfred is offline ppfred  Canada
Default Trouble with unstable bias setting.
Hi y'all,
I reworked a Dynaco ST150 a while back and in the end was unable to stablize the output bias current. It was all over the place. After blowing numerous fuses & a few transistors in trying to find the problem, I shelved the project. (2 years ago)
I have now calmed down and would like to get the amp up and running. So the question (for now) is:
Where and what should I look for to try to stablize the bias current? Is there a specific problem area or should I be worried about the whole circuit?
Thanx for any help and/or suggestions.
Fred p.
Believe nothing you read and only half of what you see.
Old 2nd January 2006, 05:36 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Usually there is some temp sensing component
that senses heat of heatsink.
If get hot, then reduces bias,
if get colder, then increase bias current.
This balances and stabilizes current.
This sensor can be a little resistor that changes resistance by temperature.
Can also be a transistor near to or mounted at heatsink.
If such a sensor, for some reason, is not enough close to heatsink
this control may not work properly.
lineup
Old 2nd January 2006, 09:11 PM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
If you have done too many changes or component substitutions, the result may be an instable amplifier. Note that when an amplifier is oscillating it's almost impossible to adjust bias properly.
Do you have an oscilloscope in order to check stability?
Old 2nd January 2006, 09:21 PM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hi Fred,
Eva's right. There are a few reasons why bias may be unstable. Everything from oscillation to intermittent connections. You need to rule out oscillation, for that you need an oscilloscope.
-Chris
Old 3rd January 2006, 12:27 AM   #5
jblmar is offline jblmar  United States
You need to know where the Bias is produced, then check the associated components. Since you have 1 working channel, use it as a reference. Don't overlook the bias VR (if your amp uses one). It may be intermittent. If so, replace it or clean with Deoxit. Try tapping the VR while monitoring the the DC offset with the DMM at the speaker terminals. An intermittent will show up that way.
Ron
Old 3rd January 2006, 12:36 AM   #6
anatech's Avatar
Hi Fred,
P1 is your DC offset (near Q1 & 2), P2 is the bias control. Transistors Q6 & 7 are related to the temperature compensation (bias). Any broken connections or intermittent contact in thse areas (except P1) will give you grief.
If you replaced some parts, can you post the numbers you put in and their positions?
I still think you need to check for oscillation with a 'scope.
-Chris
Old 3rd January 2006, 12:08 PM   #7
Hi people,
Thanks for the quick replies. Your responses were exactly what I was looking for, i.e., where do I start?
Well, for the matter of component changes, I stripped the board completely and replaced all the parts including substituting transistors - probably my biggest downfall. So I can now safely presume that the amplifier is unstable, besides all else.
I do have an oscilloscope that I picked up on E-Bay (cheap!). Now, how do I check for oscillation? Any and all pointers would be appreciated.
This whole re-build project was started as a learning experience and experiment. I guess I'm well on my way.
Thanks again for any and all help.
Fred p.
Old 3rd January 2006, 01:15 PM   #8
anatech's Avatar
Hi Fred,
Connect the 'scope probe to the output of the amp. If the trace becomes thick (0.5 mS / div, 5V / div) the amp is probably oscillating. I would expect the heatsinks to get warm to hot in that case. Some amps will not oscillate until the bias is increased beyond a certian point.
-Chris
Testing and setting bias on Zv9 sts9fan Pass Labs 2 23rd September 2008 07:45 PM
Setting Bias kptseng Solid State 9 8th March 2008 01:56 AM
bias setting ben goh Solid State 8 14th August 2006 04:26 PM
having trouble setting quiesent current? tinkerbell Solid State 35 11th April 2005 11:34 PM
Problems with bias setting Cicero Solid State 5 21st January 2005 08:01 AM
Page generated in 0.10558 seconds (78.45% PHP - 21.55% MySQL) with 10 queries
