Old 2nd January 2006, 03:59 PM   #1
ZuMbAiU is offline ZuMbAiU  Bulgaria
ZuMbAiU's Avatar
Unhappy 450W@8 Ohms Mosfet amp schematics needed
Hi everybody.I try to find any schematics of the A.H. AV800 but i cant.
I can`t buy his kit because i am from Bulgaria and can`t use the shipping.
I want make any DIY project with MOSFET`s.I have two 450W @8Ohms Drivers for this,but i can`t find any good schematics.
The AV800 is good may be for me but if i can`t find the schematics,this project is only a dream for me.
Srrr for the bad english
Old 2nd January 2006, 04:23 PM   #2
MikeB is offline MikeB  Germany
MikeB's Avatar
You could have googled...
http://schforfree.seedhost.com/archi...lifiers-linear
Goto the 800watt RMS mosfet amplifier.
Mike
Old 2nd January 2006, 04:28 PM   #3
edl is offline edl  Hungary
edl's Avatar
Dear ZuMbAiU,
450W/8ohm means about +100V/-100V rails!
I think its better to bridge 200-250W/4ohm amps.
Old 2nd January 2006, 05:16 PM   #4
ZuMbAiU's Avatar
Thank`s
MikeB
You are the guy may be for this category,but I have one very big question :
If I have big Drivers AV800 is for me?
Old 2nd January 2006, 06:31 PM   #5
MikeB's Avatar
Hi, i can't answer you the question if you need that much power... Having drivers rated at 450watts (i guess you mean speakers ?) does not mean you must attach an amp with 450watts to it.
Is this your first amp project ? If yes, i suggest to start with an amp not using lethal voltages...
Is this amp for homeuse ? Or for an SPL-contest ?
Mike
Old 2nd January 2006, 07:01 PM   #6
Electrons are yellow and more is better!
peranders's Avatar
You could check www.ampslab.com for pcb's or for inspiration.
Hypex is also an alternative, 400 or 700 W from a small cute unit.
www.hypex.nl
/Per-Anders (my first name) or P-A as my friends call me
Old 2nd January 2006, 08:10 PM   #7
ZuMbAiU's Avatar
MikeB can you help me to find the AV800 PCB design.For the moment this the problem or ...?
Old 2nd January 2006, 08:18 PM   #8
Mike
link doesn't work
All this radio needs is a fuse
Old 2nd January 2006, 08:37 PM   #9
MikeB's Avatar
Originally posted by bremen nacht
link doesn't work
For me, it does...
Mike
Old 2nd January 2006, 10:13 PM   #10
ZuMbAiU's Avatar
Mike your bandwich limit is daily or mounthly?
Can you PM`me with the PCB,because is very big and I can`t construct him.
This is my first project in the audio.I am may be a PC hardware fan ,but the sound is very big think for me.
I am with a 2xSony spakers+2xVRF=500Ws RMS,and amp Behringer.
But i want kill the time with this project and may be 2 15` Prodrivers+2 big horns and this all...
Help needed ! Inter M R300 schematics needed ! alexclaire Solid State 30 9th September 2009 06:14 AM
Any amp schematics using MTE215N10E power mosfet ? gaetan8888 Solid State 0 19th June 2007 03:55 PM
ISOBARIC 16 ohms load powered by 8 ohms Amp eddi0 Subwoofers 24 21st October 2006 03:29 PM
mosfet 450w irf240 / irfp9240 amp help aletheian Solid State 5 29th August 2005 03:20 AM
!!! schematics needed !!! hyacinth Parts 3 27th January 2005 02:04 PM
Page generated in 0.12165 seconds (74.07% PHP - 25.93% MySQL) with 10 queries
