Old 1st January 2006, 06:28 PM   #1
Default What is true balance?
What is true balance output? Mark Levinson says it has true balance design from input to output but how does it convert a RCA input to balance?
What is non-"true balance"?
What are the differences between these two?
If I have an XLR output, how do I know it is true balance?
Too many questions. Thank you.
Old 2nd January 2006, 07:55 AM   #2
it appears that the most important aspect of a balanced output is very accurate balancing of the source impedances.
The voltages seem to be less important due to the next stage being able to amplify the DIFFERENCE between the voltages.
It is the ability of the balanced input amp to work on the voltage difference that allows it to accept RCA unbalanced input with just acceptable performance.
Look up http://www.rane.com/note110.html for some balanced to unbalanced and back interconnects. there is a good section on signal grounding as well.
regards Andrew T.
Old 2nd January 2006, 08:48 AM   #3
moamps is offline moamps  Croatia
http://www.dself.dsl.pipex.com/ampin...d/balanced.htm
Old 2nd January 2006, 08:51 AM   #4
wuffwaff's Avatar
Mark Levinson refers to true balance when they use two amps (one for +IN, one for -IN) and not an inverter stage at the end of a normal gain stage.
You should be able to telll if yours is "true balance" by looking at the schematic or inside the amp.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 2nd January 2006, 03:59 PM   #5
Thank you for the responses but I am not an electronic guru that is why I am having some difficulties to understand the information as stated in the link. Anyhow, appreciate the help but would be grateful if someone can put it in more layman terms.
Old 3rd January 2006, 12:53 AM   #6
anatech is offline anatech  Canada
anatech's Avatar
Hi Aaron,
Don't you love advertising guys? Unless you know electronics and can read the schematic, there is no way to know for sure if something is properly balanced. In studio terms, "balanced" means both phases of the XLR connector are driven exactly equally, 180° out of phase. The 0 Vu level is +4 dBm (ref 600 ohms, 0.775V). That would be a good hint that it is correct. A microphone operates at a much lower level, but is balanced.
To add to the confusion, there are wiring differences between the US standard and Japanese standard. One of the phases and cable shield are swapped. I can't remember off-hand which phase it is.
A sure bet something is wrong is a 1/4" plug labeled both ways. This is almost always a +4dBm /-10dBu type. It's unbalanced as the two phases run at different levels. Avoid unless you plan to run at -10 dBu (around 0.316 V) Your RCA's standard level is also -10dBu.
Have I confused you?
-Chris
Old 3rd January 2006, 01:00 AM   #7
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Re: What is true balance?
That's how they do it in ML380 preamp:
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 5th January 2006, 07:07 AM   #8
Many thanks for the input.
For the RCA to balance conversion, I can see there is one output from OPA627 to two opamp. How does it divide the +ve and -ve because there is no caps to shift the phrase?
Old 5th January 2006, 07:38 AM   #9
Did it Himself
richie00boy's Avatar
The top op-amp is non-inverting and the bottom is inverting... simple
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
My LM4780+DRV134UA True brige balance AMP IceMing Chip Amps 5 11th June 2007 08:36 AM
Where to get balance controls? Glowbug Solid State 5 26th October 2006 08:06 AM
Quad balance ginsner Solid State 4 16th August 2006 08:04 PM
Are Balance Controls Still Necessary? runeight Tubes / Valves 32 2nd November 2003 10:47 PM
Balance control 2Bak Pass Labs 4 11th July 2002 07:07 AM
Page generated in 0.09397 seconds (81.84% PHP - 18.16% MySQL) with 10 queries
