old device specs
old device specs
Old 1st January 2006, 11:26 AM   #1
$orabji! is offline $orabji!  United States
Default old device specs
I'm restoring an old early 70's one-of-a-kind amp made by a talented friend (now deceased) and am looking for the specs for these devices.
Motorola
SJ3679
SJ3678
SJ3681
SJ3680
Knowing the guy who built it, the devices are probably hand selected for CEv. Likely also selected as full SOA devices in that I*V=P where P is a constant up to the current limit. (that's how this fellow built his personal stuff) But I know not P or I. It uses 6 of the SJ3679/8 devices per channel w/ a 40V regulated supply. Runs in class A for 8 ohm load ~ 1.5A bias per side. The other devices are the drivers.
Just trying to get a better idea of what I'm working with. The amp works just fine, (better than many 'modern' amps - i.e. clean power bandwidth to over 100K, even with these old devices) and not I'm planning on replacing these devices unless it's necessary. I've been unable to find these as they are so old and my library doesn't go back that far.
This is a very advanced amp for its time.
Thanks for any info,
~ Sorabji
Old 1st January 2006, 11:37 AM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
I have no indication of the existence of these devices.
Not by number and not by Motorola Xref.
2SC36XX is possible but these would be Sanken or for the 2SC3681, Sanyo.
Could you provide a picture?
/Hugo
Old 1st January 2006, 12:21 PM   #3
Onra is offline Onra  Germany
i looked up an older ECG-list and found ECG-replacements for three of them:
SJ3678 is NPN replaced by ECG130 (maybe a 2N3055), TO3,
SJ3679 is PNP replaced by ECG219 (complementary type of ECG130), TO3;
SJ3680 is NPN replaced by ECG175 high voltage audio in case TO66
SJ3681 not found in this list, but ECG┤s complementary type to ECG175 is ECG 38 in same case and voltage range.
Onra
Old 1st January 2006, 12:53 PM   #4
peranders is online now peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
old device specs
$orabji!, if you by any chance have a schematic I'm pretty sure that the gathered expertize here can find suitable replacements.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 14 pcb's in interest.
Old 1st January 2006, 01:44 PM   #5
Netlist's Avatar
Onra made me dig a little deeper.
So, for the SJ3678 we have:
VCB:100
VCE:60
VEB:7
IC: 15
PD: 115
ft: 800Khz
Hfe: 40
SJ3679:
VCB:100
VCE:70
VEB:7
IC: 15
PD: 150
ft: 4Mhz min.
Hfe: 20 min.
SJ3680:
VCB:500
VCE:300
VEB: 6
IC: 3
PD: 40
ft: 10Mhz
Hfe: 50 typ
ECG38 (no SJ3681 here as well)
VCB:400
VCE:350
VEB:6
IC: 2 cont. 5 peak
PD: 35
ft: 20Mhz
Hfe: 50typ
/Hugo
Old 2nd January 2006, 02:19 AM   #6
Many thanks!
Old 2nd January 2006, 04:24 AM   #7
anatech is offline anatech  Canada
anatech's Avatar
old device specs
Hi $orabji!,
Those do sound like old Motorola part numbers for "factory numbered" devices. Motorola will have no specs on these numbers. They are like a state secret.
Be very cautious of subs listed by ECG or NTE. Do not cross in and out of these manuals.
Hugo,
Where did you find listings for those? Just curious. These numbers remind me of older Marantz part numbers.
-Chris
Old 2nd January 2006, 09:35 AM   #8
Netlist's Avatar
Data comes from an old '89 ECG catalogue.
Indeed, one can only hope the info is reliable.
http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/$$Search?OpenForm already lists different specs for some devices parameters when looking at the datasheets.
/Hugo
Old 2nd January 2006, 11:53 AM   #9
djk is offline djk
djk's Avatar
Chris is right, they look like house numbers used by Marantz.
The outputs are the 2N5631(NPN), and the 2N6031(PNP).
The drivers are the 2N3584(NPN) and 2N6421(PNP)
old device specsHide this!Advertise here!
ESL AMT device... moray james Planars & Exotics 8 16th January 2007 03:45 AM
Device like upc1298 palesha Solid State 5 26th January 2006 01:09 AM
IC Echo device Ubijoux Instruments and Amps 5 6th December 2005 11:51 AM
Tuning Device sma Multi-Way 1 12th October 2004 09:59 AM
Single device (BJT/FET?) amp? RichardJones Solid State 2 19th April 2003 11:06 AM
