Help for Cambridge A300 please - diyAudio
Old 27th December 2005, 09:42 PM   #1
Justcallmedad's Avatar
Default Help for Cambridge A300 please
One channel of the A300 is out, it seems to be around the bias setting. The trim (RV202) is burnt and so are the R238,239(?) R260, R236. I guess what would help me the most would be to get the schematic: would anyone know where I can find it? I join here a photograph to show the burnt part . Have you ever experienced that or heard of that kind of problem? does anyone of you have any insight/idea/suggestion to help me solve it?
Thanks a ton!
photos
Richard Perez
Old 28th December 2005, 12:34 AM   #2
anatech is online now anatech  Canada
anatech's Avatar
Hi "Dad"
Sounds like outputs and drivers have failed, plus the other parts you have listed.
Check the rest of the transistors in that channel. Also have a look at the low value resistors (<1K ohm). They may be open, but look fine.
-Chris
Old 28th December 2005, 05:55 AM   #3
Hi anatech,
Yes I guess that the SAP10 have failed, probably after a short at the output (It's my daughter amplifier), which are the drivers ? have you an idea of the output stage/drivers design? Before removing parts and check them I would prefer to know a little more about the design, If can't get the schematic, I will "backengineer" the PCB, but you know it's a little fastidious !
Richard Perez
Old 28th December 2005, 07:14 PM   #4
anatech's Avatar
Hi Richard,
Measure the resistance between the speaker output (before the relay) and each DC supply. Look for a short reading.
The drivers are the transistors the connect to the outputs, normally between the VAS ond outputs. I would need a schematic is give you more accurate answers.
Drawing the schematic from the board will take some time. I've had to do it, it's not fun.
-Chris
Old 28th December 2005, 09:13 PM   #5
JohnW is offline JohnW  Czech Republic
JohnW's Avatar
Hi Richard,
Cambridge A300 V2 Power section,
Good Luck,
John
Time is my worst enemy!
Old 29th December 2005, 10:27 AM   #6
Thank you very much JohnW, the schematic was very helpful, the problem is solved now I just replaced the 2 Sanken power Darlington’s and the burned resistors R214 R216 R225 R230 RV201 (on your schematic).
By the way, if you have some insight on this amplifier do you think that replacing the feedback resistors by better ones (Resista, Caddock) and capacitor C203, as well as the input cap by Black Gate NX ones, could significantly improve the sound? Or maybe have you other suggestions.
Thanks again.
Richard Perez
Old 11th January 2006, 03:22 AM   #7
Send a message via MSN to carl.stock
John,
You didn’t happen to design the A300 v2, seeing as you have a schematic, did you?
Just curious!
Carl
Old 13th January 2006, 01:25 PM   #8
JohnW's Avatar
Hi Carl,
The Cambrodge Audio A300 was designed after I left AP (Audio Partnership) the holding company for Cambridge Audio and many others.
The original CA amps, A1 & A2 where designed by Mike Creek of Creek Audio Fame...
Together, we had a many a "Fun" time in China getting the earlier AP products in production - like avoiding 10lb Rats and coming to terms with the holes in the ground called toilets (we soon learnt to carry own rolls of toilet paper...)
To the "good old days"
John
Old 13th January 2006, 03:17 PM   #9
tja is offline tja  Netherlands
You forgot the cockroaches?
Old 22nd January 2006, 08:43 PM   #10
Hi! I'm going to buy one of the named amp. Can anyone of you send me the full schematic for the amp please? I would be much happier if i had the chance to repair it if anything goes wrong.
Cambridge CD3 - need help Dyolf Digital Source 4 21st May 2009 07:52 PM
A&R Cambridge A60 help steve_v Solid State 13 27th December 2007 10:28 AM
Can I replace the 1M volume pot with a 100K one in my HK A300? Bing Yang Tubes / Valves 0 18th March 2007 01:01 PM
cambridge a300 running hot reddish75 Digital Source 3 16th January 2007 03:57 PM
Where to get PPI A300 mosfets? rfp25n05 Jexx Car Audio 6 18th July 2006 03:55 AM
Copyright ©1999-2017 diyAudio
