i have smp40n10 power mosfet can i use it in power amp
thank for reply |
#2 |
How many do you have?
Cheers
http://sites.google.com/site/quasisdiyaudiosite/ |
#3 |
i have 20
#4 |
You can build a quasi-complimentary power amplifier with DC rails of +/- 47v (at idle) maximum. You are welcome to use this circuit.
http://www.diyaudio.com/forums/showt...751#post781751 If you do, a couple of component changes need to be made so let me know and I'll work out the changes. This circuit will give you about 90 - 100 watts RMS into 8 ohms and about 160 - 180 watts RMS into 4 ohms. For a high quality and powerful stereo amp, the main parts you will need are; 4 FETS per amplifier board A 300va to 400va transformer (depending on the use of your amp) 2 x 25 amp bridge rectifiers 4 x 10,000uF 63v capacitors Other parts will depend on which circuit you select. There are a few in this forum that can be adapted. Cheers
#5 |
hi quasi
i look for amp on 25-30 watts range. i whant to make a multichanel amp for my home theater sytem with a relative good sound quality. your design seem to be realy realy good prob i try this for my sub. do you have a good shematic for 25-30 watts or a link. thank you very mutch for your repply i realy apreciat this. ps... sorry for my poor english hihi my language is french . |
#6 |
For 25-35 watts I would build a chip amp. I.e. an IC based power amp. You can make these units on small PCB and you would easily get 5 amps and power supplies into a medium sized case.
Have a look in the Chip-Amps section for a design. There would also be plenty of designs on the web. Cheers
| Power MOSFET | chlim74 | Car Audio | 17 | 20th May 2012 02:49 PM |
| MOSFET power amp help | pollypocket | Solid State | 19 | 7th December 2006 06:01 PM |
| Hi-power mosfet | Stefano | Pass Labs | 1 | 20th October 2003 09:03 PM |
| MOSFET Power Follower help | RichardJones | Solid State | 0 | 28th January 2002 06:01 PM |
| Page generated in 0.08772 seconds (68.75% PHP - 31.25% MySQL) with 10 queries |
