I got a new amp, and i figured along with it I would get a good power cord, and what the heck while I was at that I figured I would get a new power cord for my other amp as well. Unfortunately I didn't check the back of the other amp. Its a NAD C320BEE, I had remembered that it had a socket and so I thought I could plug in a new cord no problem. Well it has a ac socket I guess to plug in another piece of equipment to it. My question is how easy would it be to rig in a IEC receptacle so that I could plug in the new cord. Is it risky? I've never really done anyting remotely diy with amps and I dont really care to go about breaking anything. It looks like it would be simple enough but like I said I dont really know. And is it worth it? Its an absolute power cord that cost me 50 bucks.. would I be better off just saving it for perhaps some future application? Thanks for any help!
Bruce |
#2 |
I would not do anything to a NADC320BEE
I would be glad to own one. It has the potential to become A Real Classic Amp In the future. I have had thoughts about buying one myself..
lineup |
#3 |
Bruce,
To answer your question (and with respect to what Lineup said), it should be very easy to change the power socket on any amplifier. I am a little confused when you mention that "it has an ac socket to plug in another piece of equipment." If this is an ac outlet socket connected to a main mains (input) receptacle to supply power to ancillary equipment, then there might be serie fuses/switches involved. So, to qualify, it should be easy provided you do the right thing! IEC is pretty much the standard thing so the conversion might be prudent. But if the amp has collector value as Lineup suggests, perhaps you should use an intermediate cord. If you feel hesitant, I am sure you can consult with a knowledgeable electronic friend. A power chord costing $50? Regards |
#4 |
I would not modify the power cord for this amp.
The chance of improvement is close to zero. The chance of worsening is 50%. The chance of dramatically reduced safety is 80%. The chance to loose any potential for collector value is 99%. ...just my two cents. Save the new cord for another component, where you can use it without modification. |
#5 |
If you do decide to modify the power connector, be sure to isolate / remove the original cord, otherwise the mains voltage will appear on it
Sorry if that's obvious, but better to be sure! |
#6 | ||
http://www.nadelectronics.com/hifi_a...closerlook.htm
lineup |
#7 |
Don't mess with AC inputs until you get some experience with low voltage stuff first... AC wiring inside an amp is not a good place to start.
Take your $50 cord back... and after whipping the salesman a few times with it... get your money back. If you still need a cord, go to a computer store and buy a heavy duty one for a monitor... $8 tops. Fancy power cords for audio are pure BS... Take the other $42 and send it to me!
#8 |
I did this on a amp because the original word was in my eyes too thin for a 2x100w amp and that it was damaged where it came out of the plastig retainer. I changed it to a IEC connector and actually experienced a tad better sound as the power cord got thicker as well as better on handling current.
| X350 Power cord,not IEC? | Trigger100 | Pass Labs | 2 | 19th January 2008 07:32 PM |
| How do I diy Hi-End filter power supply and power cord? | bmpa | Parts | 6 | 24th April 2004 12:12 AM |
| Page generated in 0.08490 seconds (86.54% PHP - 13.46% MySQL) with 10 queries |
